Parking brake question
Alright my cab is in primer today and is set to be sprayed next week so im pumped and i was going through my parts deciding what needs to be painted when i came across my parking brake.... its the hand style parking brake and i DON'T like the way it looks. I was wondering if anyone knows whats involved in switching over to the foot operated version? Also, if anyone has pictures of the hand operated style that look good please post them because as it stands i think the thing looks goofy there but im open to suggestions on ways to make it look better if thats possible.
Also, if anyone has a foot operated parking brake they want to sell or trade let me know. On a side note, i have the type of gas pedal thats connected to the floor and want to buy a "dress up" set of pedals ..... does anyone know where i cam find these? If so please post a link. Thanks Chris |
huh ???
Hey Chris, give me a day to look, but I might have the floor style p brake assembly...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's "I am a bomb technician. If you see me running try to keep up!" |
#3 | |
huh ???
I've never done that swap so I'm not sure.
Chuck
i dont know for sure but I know on the parts truck i took apart the foot pedal just had 3 bolt holes under the dash that it bolted to. i would think just reroute/lengthen the cable. might check under the dash and see if they are there.
69k5 |
I think the firewall holes are diffrent for each,but I'm sure it can be done to switch.I have a 69-72 E-pedal setup
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
![]() Join Date: Sep 2001
I kinda like the hand brake - it's different - like the foot-operated dimmer switch! You might hit your hand brake with some glossy black and see what it looks like painted.
I have a Lokar unit w/brake cables that I will be selling as soon as I find my receipts. I got a good deal on it. The reason I'm not using it is because my roll cage will be in the way so I will make a custom center console and use one of Lokars pull type mounted there. Here's a picture:
'68 Short Step LS1/T56, Hydratech, Fatman Fabrications Stage III, Baer, Hot Rods to Hell, US Body, S&W, etc |
And I forgot to add Lokar makes pedals also. Here's their floor mount:
![]() And here's a shot of the firewall side: ![]()
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Damn that lokar unit is tight!!!!
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
I converted my '67 to foot brake. I'ts been awhile, but I know I got a cable for foot pedal from a later model. I had to cut the rectangular hole in firewall for the rectangular grommet that's used, and two holes to hold the front part of the foot brake assembly to the firewall. I had to do a little bending at the dash attachment point, but nothing that is noticeable. I can't remember for sure, but the holes I had to make may have been about where the stock fuse block is. I don't remember because I am going with a complete different wiring harness. I welded up almost all the old holes in the firewall and don't remember where things were. I'll try to find some pics that may help. I think I can add my pic now:
Got Light Emitting Diode?
i saw a leather wraped hand brake some where on here, it looked cool
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's ![]() 1993 Cherokee work ride/weekend wheeler |
#13 |
I'll try and sneak this past the man. Take a look on Wes' site, 67 panel project, page 5.
![]() ![]() 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
#14 | |
I guess i'll just keep my eye out for a creative way to dress up the hand operated brake. If anyone has any pics please post them. |
#15 |
huh ???
Hey GreyHoundSteve,I looked for the pbrake yesterday and couldn't find it. I must of pitched it after all...
Chuck
#16 | |
#17 |
member #16
![]() Join Date: Dec 1999
Do you have the cover? If not try a WTB on the parts board. I think they look better with cover.
John
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
#18 | |
Thanks |
#19 |
member #16
I dont think they are being reproduced, but you should be able to find a used one.
John
#20 |
E Brake cover
I have one to sell. $20 delivered to your door.
Thanks - Bob
67 C-20 LWB, tilt, speed alert, vac, 454, T400 67 C-10 SWB, factory air with more to follow |
