11-24-2004, 07:25 PM | #1 |
Lift Help?
Ok Im wanting to put a set of 35's on my truck how much lift would it take to put them on i have a 1982 chevy longbed 4x4 with no lift
11-24-2004, 08:00 PM | #2 |
Safely without hitting fenders probably 6susp.
4susp. would work but might hit if the wheel offset is to much or they are wide tires.
Support The Board |
11-24-2004, 08:01 PM | #3 |
I would guess a 4 inch. Now look at your finger and determine 2 inches...... A 6 would be nice if you are gonna wheel it at all. Not much difference in a 4 and a 6.
11-24-2004, 09:36 PM | #4 |
What was I thinking??
Lift..
You can get by with a 4in lift . I had 35's on 15x10 with a 2in lift a 1in body I did have to cut the front fenders.
Like Drink2mny said your wheel off set could be a problem but I have seen some ppl not have a problem at all. And good thing about a 4in is in most cases you will not have to have your rear drive shaft re-done. You should get the sterring arm. and take a good look at the brake lines see if they will have room to move.
72 K5 that needs lots of parts.. 71 GMC 3/4 4x4 That doesn't need much which is a good thing I don't think I could aford another money pit... |
11-24-2004, 09:42 PM | #5 |
dont wanna cut any fenders really or antyhnig but what about a 6inch lift will that do it oh yeah bad blazer
11-24-2004, 10:05 PM | #6 |
I would say if you went with a 6in you will have to get longger brake lines and have your rear drive shaft done.
Thanks on my old K5 I hated to sell that ride...My 72K5 will take a lot longger to build...
11-24-2004, 10:08 PM | #7 |
i would not have to change the rear end would i
11-24-2004, 10:11 PM | #8 |
Not with just running 35's you should have a 10b right?..In the long run what are you going to do with it?
11-24-2004, 10:46 PM | #9 |
just go mudding thats all
11-24-2004, 10:48 PM | #10 |
So what kind a lift do you perfer what brand
11-24-2004, 11:36 PM | #11 |
Tuff Country they have some soft spring rates. I like a lift that has some flex. And doesn't ride to much like a tank..lol
11-25-2004, 08:50 PM | #12 |
user # 2756
I have rough country on my 71 and heavy duty tuff country on my 70 and I'd say hands down the tuff country is better. the HD has a smaller spring rate than the rough country.Also, rancho springs are some of the stiffest around.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm |
