11-24-2004, 09:24 PM | #1 |
WTB:Big Block PS bracket
I need the Big block rear ps adjustment bracket I got a aftermarket one that does not fit worth shi?! So let the search begin. Thanx Dana
1972 Cheyenne K-30 6"lift {502 PROJECT} 1972 Cheyenne K-30 8"lift 454 450hp {Ol'Blue} 1972 Cheyenne K-20 Custom Stretch 6" lift 454 1972 Custom Deluxe K-20 4" lift 2007 GMC Crew Cab Diesel 6"lift {The Tow Rig 2017 Ford F-350 Crew Cab 6.7 6"lift (Wife's) 1977 El Camino SS Grandpa baught new 1986 K-30 Crew Cab 502 1955 Chevy 2-Door gasser 454 550hp{project} 1956 Chevy Bel-Air 2-Door hardtop 572 700hp 1979 Ford F-350 All Original 4x4 (Wife's) |
11-25-2004, 12:45 AM | #2 |
Senoir Member
There are 3 different top brackets on the BB p/s pump???? I have only seen one.....like a 4 inch long angle iron slightly bent. I'm interested in seeing the other 2. Greg
67 Chevy, Small back glass, Factory 4WD, Factory Shortbed, Factory V8, Lifted 4" 70 GMC Sierra Grande, Factory Shortbed, Factory 402/400 turbo, Super Custom Interior. Numbers matching with SPID & Build Sheet. 68K Original Miles. Restored 2010 70 GMC Restoration Pictures http://67-72chevytrucks.com/gallery/...00&ppuser=4424 |
11-25-2004, 07:12 PM | #3 |
I need the bracket that goes on the lower back side of the pump that bolts to the header or exhaust manifold. If you guys need a pic of the aftermarket one I can get it tonight or friday. Thanx Dana
11-25-2004, 09:57 PM | #4 |
Senoir Member
I'm confused...I thought the bracket that bolts to the exhaust manifold went to the top of the p/s pump for tension adjustment. Does it look like a bent piece of angle iron about 4 inches long, a hole in one end and a slot on the other end? If not, the picture would be a great idea.
Check this site http://www.truckandcarshop.com/60_72Truck.html Look on page 143, item 68-14308. Hope this helps, Greg
67 Chevy, Small back glass, Factory 4WD, Factory Shortbed, Factory V8, Lifted 4" 70 GMC Sierra Grande, Factory Shortbed, Factory 402/400 turbo, Super Custom Interior. Numbers matching with SPID & Build Sheet. 68K Original Miles. Restored 2010 70 GMC Restoration Pictures http://67-72chevytrucks.com/gallery/...00&ppuser=4424 Last edited by gregbr; 11-25-2004 at 10:05 PM. Reason: Add info |
11-25-2004, 11:15 PM | #5 |
Yeah, that's the piece and it is a piece of crap. It's too wide and it just won't fit snugly in that tight spot!!
11-26-2004, 06:53 PM | #6 |
Ttt
11-28-2004, 03:10 AM | #7 |
Nobody has an original??????????????????????
