Old 11-24-2004, 09:49 PM   #1
gldevall
gldevall's Avatar
Attn: Ocbaud and TIMSPEED
Didn't you guys have flywheel problems? Cracked or broke. What did it do? Did it knock?
Gary -1986 SWB: lowered 4/6, SOLD!!!
-Best 1/4 mile: 14.51 @ 91.01 MPH
-2001 Pewter Tahoe, billet grill, Corsa Sport Cat-back, K&N FIPK SOLD!!!
-2004 Z-71 Extended cab with a flowmaster, BDS 6.5", 3" BL, 35x12.5x18 Trail Grapplers on Pro-Comp 18x9 wheels
gldevall is offline   Reply With Quote
Old 11-24-2004, 09:58 PM   #2
ocbaud
Garage Queen Material
my stock flexplate was cracked pretty bad about a year and a half ago on the 305. i had a shop replace it along with the rear main seal that was leaking.
the ticking wasnt noticable while driving, but you could hear it if i went in reverse at any speed whatso ever. it would make the ticking sound every once in a while right after i come out of park and tap on the gas in drive.
picture this:
the big round holes that are all around the flexplate. well, i had cracks running from at least 4 of the crank bolts all the way to each of those holes.
ocbaud is offline   Reply With Quote
Old 11-25-2004, 12:46 AM   #3
Slonaker
Insert Witty Text Here
Slonaker's Avatar
When the flexplate on my friend's C10 cracked, it just made a clicking sound when the engine was running.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 11-25-2004, 01:03 AM   #4
BowTieMan
BowTieMan's Avatar
My 88 4.3 blazer makes a high click at idle. Then when you go to about 1500 rpm it speeds up then at 2000 its completely gone. And when I kick the air on at idle - 1500 its is a really loud fast click. And it sounds like it is coming from under the truck and the back of the motor. Think its the flexplate?
"A true hotrodder wouldn't be content untill he had created a car so violent, so hairy, so totally sick that the very act of dropping the hammer would result in instant death. Anything less results in the need to go faster." - Tony DeFeo
BowTieMan is offline   Reply With Quote
Old 11-25-2004, 01:21 AM   #5
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
Mine the whole center broke out from the rest of the flexplate. Funny thing was it still started right up and not even a hint of it being bad. I found this out when I changed the transmission that went out. If you loosen the convertor and push it back. Take a screwdriver metal end and tap the flexplate. If it rings like a bell its said to be good, if its dull its said to have a fracture in the flexplate.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 11-25-2004, 01:36 AM   #6
ocbaud
sounds like it is
Old 11-25-2004, 01:33 PM   #7
gldevall
gldevall's Avatar
That is what I think it is. It is a $20 flywheel from AutoZone. I figure I have between 300-350 ft/lbs of torque running through it. I don't think that it is strong enough to handle that much
Old 11-25-2004, 03:10 PM   #8
cochran63
cochran63's Avatar
I didn't want these problems with my BB so i ordered a tci one for my truck.
Youth soon passes away, but immaturity can last a life time.
cochran63 is offline   Reply With Quote
Old 11-25-2004, 06:08 PM   #9
TIMSPEED
TIMSPEED's Avatar
I didn't have flexplate problems..just had the wrong starter. Now, my truck starts nice and queitly.
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
Old 11-25-2004, 06:50 PM   #10
ocbaud
qft
i got a nice sfi approved tci one for my engine
Old 11-25-2004, 06:51 PM   #11
SanitysBane
i got a generic sfi arpoved, good enough for me
'96 Nissan Pathfinder
'02 Firebird Trans Am.
'88 K5 Blazer
SanitysBane is offline   Reply With Quote
