Old 11-25-2004, 11:10 AM   #1
Nima
Blue 67
Painless or Ron francis
Happy thanksgiving to all:
I am getting close to order my new wiring harness and I guess I narrowed it to these two brands. Which one do you prefer or think is better? Ron Francis seems to be 30 t0 40% more expensive. Thanks.
Nima
Nima is offline   Reply With Quote
Old 11-25-2004, 11:13 AM   #2
Russell
Professional Grade
Russell's Avatar
Painless will be perfect for you, I have yet to hear anyone say anything negative about them
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 11-25-2004, 11:13 AM   #3
ChevyDude
M&H....if you want it to look Identicle to the stock GM harness.
Alex
1971 Lil' Red 350 SBC 700R4
ChevyDude is offline   Reply With Quote
Old 11-25-2004, 11:41 AM   #4
68LSS1
68LSS1's Avatar
Ron Francis. But Ron Francis can put the connector you will need for later model GM columns or the aftermarket ones. They can put the connector on it for the alternator that you will be using (one wire, integral regulator, etc). Got a HEI distributor? They can put that connector on. Personally, I'd go with the M & H over the Painless if your running a stock set up.
'68 Short Step
LS1/T56, Hydratech, Fatman Fabrications Stage III, Baer, Hot Rods to Hell, US Body, S&W, etc
68LSS1 is offline   Reply With Quote
Old 11-25-2004, 11:50 AM   #5
Randy70C-10
Randy70C-10's Avatar
I've installed three Painless kits so far and love'm. They are very easy, trouble free, and fairly inexpensive.
Randy70C-10 is offline   Reply With Quote
Old 11-25-2004, 12:22 PM   #6
Nima
Blue 67
I don't have HEI yet but that's gona changed at the same time I do rewiring (I hope it is not too complicated to do them at the same time!). Also, under the hood is not all original and I don't mind upgrading or new looks, therefore stock look is not that important for me but I appreciate all different inputs.
Old 11-25-2004, 12:24 PM   #7
Kid
Kid's Avatar
I have used M&H also and am very impressed. They are easy to get help from over the phone also. Never used Painless, so can't say good or bad.
Kid is offline   Reply With Quote
Old 11-25-2004, 12:27 PM   #8
70c10
67-72 Addict!
70c10's Avatar
Randy, did the Painless kit include the factory style connectors for the wiper motor, ignition, headlights, heater, etc.,?. If it did, are they already attached or do you just splice them on?
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 11-25-2004, 01:27 PM   #9
Randy70C-10
All connectors are already attached for everything under the dash, all you have to do is plug everything in. The lights and engine section you have to trim to proper length and terminate with connectors. It's very easy and makes for a cleaner installation because you can route the wiring however you wish since they give you an extra couple of feet to work with.
Old 11-25-2004, 01:28 PM   #10
gonebad2
Merciless Butcher
gonebad2's Avatar
I went with a Painless too.....No problems to report here.
Your Bought And Sold....I Got Your Soul!
gonebad2 is offline   Reply With Quote
Old 11-25-2004, 01:45 PM   #11
Randy70C-10
Here's some of the under-cash wiring to give you an idea.....
Old 11-25-2004, 03:49 PM   #12
Wootdog
Wootdog's Avatar
Painless
I agree with Randy. I did my 67 wiring harness with painless, and yes it is painless. Now for the 68 I will go that way again. Kerry
1967 C10
Got it back after three years
Boy I sure missed Peppy
1969 Chevelle
1990 IROC Z Convertible
2002 Silverado LT
Wootdog is offline   Reply With Quote
Old 11-25-2004, 06:31 PM   #13
Vince Putt
Hippy
I was The very first customer of Painless Wiring. Some twenty years ago I believe. I was so impressed by what they offered I asked what would it take to be a dealer Dennis and his partner looked at each other and grinned, I thought they were going to HI-Five on the spot. I've been using their products ever since. It keeps getting better and better.
Vince Putt is offline   Reply With Quote
Old 11-26-2004, 12:14 PM   #14
GreyHoundSteve
I bought my painless harness from O'reileys because autozone was out of stock. It looks great and should be a cinch to install.
GreyHoundSteve is offline   Reply With Quote
Old 11-26-2004, 12:30 PM   #15
Harold Shepard
Depends on what you want now and later, the painless is labelled and comes with connecters but needs some things imo. If you have plenty of time and know your way around these trucks well then go with the painless- especially if the stock look s not your thing. Otherwise go with M&H. They plug right in- no crimps you have to do (less chance for operator/installer screw- up) they have the correct connectors, no hunting or robbing from the old harness, and you will be done and resady to roll in 2 hrs tops for complete truck, painless 8-12 hrs- as there are crimps to make, wires to cut, decissio to tape or sheath and zip ties to install. Was not a hard decission for me... M&H
Harold Shepard is offline   Reply With Quote
Old 12-02-2004, 09:09 PM   #16
benoit454
Chris
benoit454's Avatar
Where can I find this M and H wiring harness? Is it for 73-87's?
Old 12-02-2004, 09:45 PM   #17
4x4Poet
I have no experience with complete, replacement wiring sets/harnesses, but I was at a local customizing shop today and talked with the owner about an engine swap they'd done into a '60s F#$d. They also had put in a complete wiring harness tailored to the engine & vehicle combo. He said he used to use Painless, but once he compared them to Ron Francis stuff, he's used RF ever since. He said RF is admittingly more expensive but worth the extra cost.
He liked the overall quality, pre-terminated ends, new-style blade fuse block, and especially how each wire has printing on each wire's sheath every six inches or so saying what each wire goes to. So, if you are routing a wire away from its start or terminus, you can see at a glance what circuit you're working with. Does Painless do the same with their wiring harness wire sheaths?
Never heard of M&H. I, too, would like to view their website and know if they are the supplier of "factory original" wiring harnesses found in 67-72 Chevy truck part suppliers' catalogs.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 12-02-2004, 10:17 PM   #18
ChevyDude
Just replaced both harnesses up front under the hood (lights and engine) and it could not have been easier. They were M&H and all I did was remove the old two harnesses and plug in the two new ones. THey fit exactly like the originals. I was done in about an hour.
Alex
Old 12-03-2004, 12:41 AM   #19
imdarren
imdarren's Avatar
Ok. Does anyone have info on where to get M&H products?
A web site maybe?
Or is M&H part of the Ron Francis product line? I'm confused because I've never heard of M&H.
Thanks!
Washington State
1967 Chevy C10 LWB Rodstoration In Progress.
1972 K20 Cheyenne Super
imdarren is offline   Reply With Quote
Old 12-03-2004, 02:51 AM   #20
1972
Majician
1972's Avatar
via google
1972 is offline   Reply With Quote
Old 12-03-2004, 09:33 AM   #21
4x4Poet
Thanks, 1972, for helping out us lazy posters!
