Old 11-25-2004, 08:21 PM   #1
Warbones
Navel Inspector
Warbones's Avatar
Replacing gas tank.
I can't seem to get the new one in. I can get into the filler hole but then the passenger side is stuck in front of the seatbelt and on a bracket on the floor board. Anyone have any ideas there? Looks like I'll be needing cab corners too someday soon. I'd like to replace every and all weatherstripping(if I decide to keep the cab) before any bodywork will be done.
Well, I just found a little info about what I might be doing wrong. I had the grommet in first and I read a post that says to install the tank first then thr grommet. I'll be trying that next.
1948 Chevy Aerosedan GONE! I think.
1984 Cadillac Fleetwood Brougham Coupe
WANTED 1967 IMPALA
1967 CST C10 Long Bed with a 283
Warbones is offline   Reply With Quote
Old 11-25-2004, 09:16 PM   #2
Solver
Solver's Avatar
I always put the gromet on then silicone spray it a bunch then shove it through the fill hole. I think I usally keep passenger end high when shoving tank through.
  • 1972 Cheyenne Super 20 LWB-Blue
  • 1972 Cheyenne Super 10 LWB-Black
  • 1972 Cheyenne Super 10 LWB-Red
  • 1972 Cheyenne Super 10 LWB-green
  • 1972 GMC 4x4 LWB-White
  • 1971 Cheyenne 10 LWB-Ochre
  • 1971 Cheyenne 20 Longhorn-Copper
  • 1971 Cheyenne 20 Longhorn-Black
  • 1969 Custom 10 LWB-lt blue
  • 1968 GMC 3/4 ton-green
  • 1968 1/2 ton swb stepside-silver
  • 1967 Chevrolet CST 10 LWB-green
  • 1967 Chevrolet custom 20 LWB-Maroon
Solver is offline   Reply With Quote
Old 11-25-2004, 10:00 PM   #3
JimKshortstep4x4
Smile
I install tanks like Solver does only I use hand soap (without the grit in it). This method works very well. Putting the grommet in afterwards is a job!
Jim
Old 11-26-2004, 11:45 AM   #4
70 shorty
Where's my beer?
70 shorty's Avatar
I put mine it with the grommet slid down the filler neck and then slid it up into place, then took a screwdriver and worked it into position. I also put some WD40 on it to help it slide into place. Tank went right in without the grommet to fight.
70 shorty is offline   Reply With Quote
