Old 11-25-2004, 10:16 PM   #1
charles oliver
68 camtruck
charles oliver's Avatar
WTB Kickdown Setup for TURBO 400
I need a setup for Turbo 400 to kick into passing gear, Not sure exactly what I need.
Charlie
71 GMC Jimmy 4X4
68 Huger Orange Camaro 454 with TH400 :gmc
charles oliver is offline   Reply With Quote
Old 11-25-2004, 11:31 PM   #2
Staceydude
Staceydude's Avatar
Depending on what you are looking for whether it be factory setup or aftermarket.
I just saw one on ebay (don't have the link for it, found it putting 67-72 chevy trucks in the parts section)
Summit and jegs should sell a complte kit with switch for pedal etc.
I think the one on ebay was the kind that hooked up near the carb.
Regards,
Stace
Staceydude is offline   Reply With Quote
Old 11-25-2004, 11:33 PM   #3
jhow66
jhow66's Avatar
kickdown
You should have the bracket on pedal. Switch can be bought at dealer or junk yard. Just run a wire from one side of switch to fuse panel (hot only with switch on) and wire from other side to trans switch (drivers side). Here is a picture of switch and bracket.
http://67-72chevytrucks.com/vboard/s...t=400+kickdown
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 11-25-2004, 11:41 PM   #4
breeh
Recovering 67-72 Addict
breeh's Avatar
The earlier trucks used a switch mounted to the carb and the later style was down on the accelerator pedal. I have one of the switches that mounts to the carb if you are interested (for a quadrajet). $35.00 shipped
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt.
"Friends call me cruzer cuz I like fast cars and fast women"
breeh is offline   Reply With Quote
Old 11-26-2004, 01:00 AM   #5
HuggerCST
HuggerCST's Avatar
Here is a pic of the early style that I sold yesterday here on the parts board.
Wynne
70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s.
Build thread
53 Chevy shortbed
69 Camaro
Click here to subscribe
Chevy GMC International Truck Club Louisiana Charter Member
http://www.louisianaclassictruckclub.com
HuggerCST is offline   Reply With Quote
Old 11-26-2004, 02:47 AM   #6
super72bb
Hey Charlie... I am also in need of the full assembly. So if in your travels you come across 2 by chance please let me know. I am in need of the later style I guess as my truck is a 72.
Curt
1972 CHEYENNE SUPER SWB BLACK. 402 BB, TH400, AIR, TILT, TACH, BUCKETS, CRUISE, AM/FM, 8 TRACK.
My build thread:
http://67-72chevytrucks.com/vboard/s...=1#post7120181
super72bb is offline   Reply With Quote
Old 11-26-2004, 07:58 AM   #7
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I used the Lokar kit. It works as well or better than the factory unit and you can buy one from most mail order houses.
Old 11-27-2004, 09:35 PM   #8
charles oliver
68 camtruck
Th 400 Kick Down
Do you know if that will fit a Holley ? or what others it might fit?
Charlie
71 GMC Jimmy 4X4
Old 11-27-2004, 10:45 PM   #9
breeh
breeh's Avatar
I am not sure if it will fit a Holley or not. The Lokar setup is a nice unit though. It mounts down on the trans for a nice clean install.
Old 11-28-2004, 10:56 AM   #10
tom hand
CCRider
tom hand's Avatar
On the 71/72 all you need is a switch that you can buy at most parts stores....the bracket is already there...on the gas peddle.....you just mount it and run two wires
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
