11-26-2004, 10:19 AM | #1 |
PLASTIC or STEEL tank?
im fixing to attemp a fuel tank relocation project and was wondering what is the best way to go plastic tank or steel? and if anyone knows a kit that holds more gas than stock please let me know . thanks for any help you guys
11-26-2004, 10:25 AM | #2 |
Steel for sure.
11-26-2004, 11:24 AM | #3 |
go with the steel tank.
http://www.picturetrail.com/jwill41 67 1/2 ton GMC short step side 68 1/2 ton Chevy long fleet side 72 1/2 ton Chevy Suburban 99 1/2 ton Chevy Suburban founder (and only member) of the primer/clearcoat club |
11-26-2004, 11:39 AM | #4 |
PROJECT 7DEUCE
Steel would be my choice..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
11-26-2004, 01:05 PM | #5 |
"Trucks with Class"
Steel looks better.
Plastic doesn't rust inside or out for daily driver's that sit out in the weather...like all this rain in the NW! |
11-26-2004, 04:10 PM | #6 |
Will the steel(Blazer) tanks accept a fuel injected in-tank fuel pump??
I know what your thinking.......I have ESPN. Sometimes it's easier to do things the hard way. Fesler Built 1968 Chevy C10....Must resist the urge to mess with it!! |
11-28-2004, 10:35 AM | #7 |
I have the MTS 21 gal poly Sub/Blazer tank in my K10 Sub. Works fine, but, prior to install, I had to wrap a corner in Thermo-Tec Cool-it heat deflecting tape to protect it from radiant heat that emanates from the exhaust pipe 3-4" away. No problems, just a precaution taken per MTS's instructions. Something to consider, especially if you have a shortbed with a dual exhaust.
On my Sub, I still have 2-3 feet overhang behind the tank, so it doesn't hang to low. Since it's a replacement tank, it doesn't hang lower than the factory tank, obviously. I mention this because FCG makes a superior tank for pickups doing the underbed conversion. Much better than off-the shelf tanks. I only have the poly because I bought it years ago and I'm selling the K10. I'll eventually upgrade my K20 to a custom FCG tank or maybe even ECE's $800 27-gal SS tank. I have big plans.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup. Last edited by 4x4Poet; 11-28-2004 at 10:55 AM. |
11-28-2004, 10:48 AM | #8 | |
I believe ECE uses a separate hole (thru a removeable manifold) to mount any in-tank fuel pumps in their 27 gal Sub Tank, but I know that the combo sendor/in-tankd setups are available. I have a source amongst my papers. The main trick is getting the right length float arm and pick-up tube below the pump. Maybe a google search?
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup. Last edited by 4x4Poet; 11-28-2004 at 10:54 AM. |
12-05-2004, 08:56 AM | #9 |
thanks for all the info you guys are very helpful every time i think i going to go with steel
