Old 11-26-2004, 04:44 PM   #1
skokie
skokie's Avatar
Booster Rod
Can you adjust the rod distance from the booster without having to disconnect the master cylinder?
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 11-26-2004, 09:54 PM   #2
jhow66
jhow66's Avatar
Are you asking about the one under dash?
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 11-26-2004, 10:42 PM   #3
skokie
skokie's Avatar
Yes I am. Also is there a way to adjust the one on the booster where the master cylinder connects?
68 build thread
Old 11-26-2004, 11:14 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
if you are talking power brakes, i think the one under the master cylinder is the only adjustment. You don't need to disconnect the lines, just the two 9/16 nuts and pull the master cylinder away. The lines will give you enough room.
Old 11-26-2004, 11:51 PM   #5
jhow66
jhow66's Avatar
Your brake pedal should touch the rubber bumper under dash and have a little free motion when you go to apply the brakes.
Old 11-27-2004, 03:37 AM   #6
skokie
skokie's Avatar
Brakes Update:
I replaced the master cylinder. I bench bled it. I didnt have time to bleed the entire system but there is some improvement. I am going to bleed the system tomorrow and I will let you guys know what happens. Thanks
68 build thread
