Hidden wiring???
Can I get some ideas and pics on how to hide the wiring under the hood? PLEASE, thanks guy.
Troy
'72 C-10 w/ '68 Large Journal 327cu.in. "It's o.k. to dream about what you want to do, until you start doing what you are meant to do." Line from "The Rookie" |
Got Light Emitting Diode?
on my truck i put the wiring going from the fuse block to the headlights under the fender above the nner fender, then across the rad support under the rad hold downs. and the other side goes up the fire wall in to the loom thingy on the top and across to the other fender same as the other side. then the alternator stuff runs down the fire wall by the valve covers to the alternator. everything is in the black wire loom
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's ![]() 1993 Cherokee work ride/weekend wheeler |
My wire bundle runs under left fender to RAD support. Then under the RAD suppot channel ( that wasn't fun ) and then it comes out under the BATT box. All is pretty much hidden.
"72" Red CORVETTE 4-speed 350 "70" Chevy Short Bed early stages of resto. Edel 600 cfm carb Weiand Stealth Intake HEI shorty Headers 4/2 Drop 295 50R 15 TOYO on 10 inch wide corvette rally rims at all 4 corners. "CHEVY RULES" ![]() |
Put all mine in loom like 70 short did. Except for right at the firewall, no wires can be seen.
![]() ![]() ![]() LIFE AIN'T EASY WHEN YER FAT AND GREASY! GMC= Got More Class! ![]() ![]() |
I put my fuse box in the driver's side fresh air vent in the kick panel. Right now all the wiring is run under the cab and inside the frame rail, but I plan to re route it through the cowl area once I weld up the cowl vents and antenna hole.
1972 Blazer body...need to get a thread started for the rest of the story |
![]() Join Date: May 2002
Say...I was wondering if anybody makes a clutch delete plate to cover the firewall hole.
Jim Mt Juliet |
Good question! I am in the process of removing the manual gear box for A TH400.
hart
70short why all the visible spotwelds or at least I think there spot welds
To my knowledge noone makes the little blank off for the firewall clutch hole. You need to find a junk cab that had an auto trans. or just make the blank-off out of sheet metal and secure with one screw and gasket or weld in.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction. ![]() ![]() ![]() |
There factory spot welds. One day I plan on doing A frame off. Then I will shave the firewall. As of now when I pop the hood to show somebody they pretty much freak out because they don't expect it to look that nice, and believe me it looks awesome. You really don't notice the spot welds.
There is a factory block off plate for the clutch rod hole.There is a gasket.And it is held on by 2 screws.Maybe some can post a pic of it!
69 Lwb C-10 402/700R4 70 Lwb C-10 250/3pd Wisc. |
hart
It look great I thought you had done a frame off for It to look that good maybe someday Ill get my stepper done
#13 |
Thank you it makes me feel good when someone compliments me on it. It was alot of hard work.
Gary
#14 |
3-M makes a clutch delete plate product. It's cheap & easy to install, Comes in a roll that's a nice silver finish,and sticky on one side. It has many other uses too.
#15 |
purple gas, You'd be really amazed at what you can do with the adhesive backed aluminum that the hvac guys use. I once saw one of my teenage neighbors rechrome a bumper with it and chrome his differential cover too!
#16 |
my father-in-law calls it "Oklahoma Chrome"
http://www.picturetrail.com/jwill41 67 1/2 ton GMC short step side 68 1/2 ton Chevy long fleet side 72 1/2 ton Chevy Suburban 99 1/2 ton Chevy Suburban founder (and only member) of the primer/clearcoat club |
#17 | |
Still drivin' a Rat Rod
Rusty Member #13872 Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#* 71 GMC LWB 49 Chevy 85 Chevy G20 Check out my website |
