Old 11-27-2004, 02:15 AM   #1
cochino12
It followed me home?
cochino12's Avatar
Advantage to 305 heads?
What is the advantage of using 305 heads on a 350? I know a couple guys running that setup and was curious about the advantages/disadvantages
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 11-27-2004, 02:54 AM   #2
r0lf-
Hotwheels?
r0lf-'s Avatar
Ask them what they are smoking, because there really arent advantages. I know some LS1 guys run 5.3 heads to bump compression, but thats because of the computer.
Anybody can change some pistons and have higher compression that way on a carbed motor. 305 heads will flow a TON less than 350 heads.
1978 Money Pit - CUSTOM DELUXE!!!!
r0lf- is offline   Reply With Quote
Old 11-27-2004, 05:16 AM   #3
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
I dont really see the logic in it. I understand if that's what or all your can afford (good deal on them or something). All I have ever seen people talk about is the added compression from them. But the heads dont flow all that well, it will work but dont expect anything special out of it. So all the advantages are pretty much canceled out by the negatives. The swirl port tbi heads unless worked over are not all the good either. Kind of a loaded question not knowing your intentions for the heads or application.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 11-27-2004, 11:07 AM   #4
dons454s
dons454s's Avatar
they are smaller chambed but as said dont flow at all
dons454s is offline   Reply With Quote
Old 11-27-2004, 11:52 AM   #5
badone07
Project 2 Resume
badone07's Avatar
Depending on casting number, they can work well. I would only use the 416 or 601 castings though, if I wanted to retain the perimeter style valve covers. Plenty of info here...
http://www.thirdgen.org/techbb2/foru...?s=&forumid=13
John
1984 C30 Chevy Crew Cab Dually
1998 Jeep Cherokee 4x4
2004 Chevy Trailblazer 4x4 (wife's)
1970 Mustang FB fully tubed (getting 521 BBF & powerglide)
1978 Nova 2dr (going BBCaddy & S.P. th400)
1984 Monte SS (circle track car)
badone07 is offline   Reply With Quote
Old 11-27-2004, 11:52 AM   #6
Mike76251
Massive shrouding due to the small bowl diameter,
cheap junk cast iron,
imported
That's why I only paid $30 for a rebuilt set off eBay a few years back........still have em' and they are not worth the shipping fee.
Mike76251 is offline   Reply With Quote
Old 11-27-2004, 01:27 PM   #7
SanitysBane
with the cost of fast burn heads from GMPP
http://www.sdpc2000.com/catalog/3129...nder-Heads.htm
i would just get new heads personally
'96 Nissan Pathfinder
'02 Firebird Trans Am.
'88 K5 Blazer
SanitysBane is offline   Reply With Quote
