11-27-2004, 03:48 AM | #1 |
Need a rebuilt power steering box
Need a rebuilt power steering gearbox for a 1972 1/2 ton 2wd. If anyone can point me in the right direction.
Thanks Curt
1972 CHEYENNE SUPER SWB BLACK. 402 BB, TH400, AIR, TILT, TACH, BUCKETS, CRUISE, AM/FM, 8 TRACK. My build thread: http://67-72chevytrucks.com/vboard/s...=1#post7120181 |
11-27-2004, 05:40 AM | #2 |
On the road
You can get them at most auto parts stores, I recently bought one for my 98 Z71 from a bumper to bumper auto parts store. A bit pricey but worked well. I think mine was about $230 or so but a older 2wd would be cheaper. They are easy to rebuild yourself though if none of the hard parts are bad,all the seals/ bearings are available from any parts stores. I did my 72 a few months ago but mine had leaks mainly. After adjusting it out on the bench it was good and tight and no leaks. hope this helps,
Mike
Mike Castro- 72 SWB. Ochre and White. 496/400 turbo, GV OD ,Dakota Digital dash , tilt, Vintage Air, PS, hydro boost, factory buckets, console, QA-1 Coil over suspension, 20/20"Billet Specialties Magnetos 72 SWB. Med blue. 454/400 turbo, tach, tilt, Stock AC, PS,PDB, factory buckets, console, ECE 4/6 drop w/ 2" blocks and C-notch, 20/20"Coys- Crashed and destroyed by drunk driver Sept 2019. New 72 build in the works. My new build thread "Castro" https://67-72chevytrucks.com/vboard/...d.php?t=820934 My old build thread, the blue truck http://67-72chevytrucks.com/vboard/s...d.php?t=271489 www.louisianaclassictruckclub.com |
11-27-2004, 08:32 AM | #3 |
Rusty Rockerfeller
I got this from www.advanceautoparts.com website,seems like decent prices,but i think i would just stick a kit in mine too if the gears were ok.
Cardone 275004 Steering Gear: Reman.; Manual Steering Lifetime Limited Warranty Ships in 1 day Weight: 17 lbs. $248.88 $220.00 core Cardone 277501 Steering Gear: Reman.; Power Steering Lifetime Limited Warranty Ships in 1 day Weight: 32.6 lbs. $187.77 $75.00 core Lares 1074 Remanufactured; Power Steering Lifetime Replacement Warranty Ships in 1 day Weight: 31.5 lbs. $149.99 $50.00 core Lares 855 Remanufactured; Input Shaft Has A Flat Side; Manual Steering 1 Year Replacement Warranty Ships in 1 day Weight: 14 lbs. $212.19 $75.00 core Last edited by bigunde; 11-27-2004 at 08:34 AM. |
11-27-2004, 12:01 PM | #4 |
steering box
I just bought one for my 69 thru LMC. I was very pleased with the parts and the price was good.
