Hydro clutch setup advise needed
after 2 back surgeries really need to go to a hydraulic clutch behind my bigblock. surely someone has done this allready for a 72 4x4. probably go back to a nv4500 at the same time now that gas is so cheap. any help out there...........
1972 3/4 4x4,14bolt locker rear, dana44 lock right front, sm465, sb 400, blazer tank,dual batterys,3"lift,32-9.00-16 super swampers daily driver other trucks 1972 1 ton dually 4x4,454 4 spd,,235-85-16, flat bed front and rear winches, rear gas tank and under bed gun safe.tilt wheel |
Watch out for your cornhole !
![]() Join Date: Jun 2003
8mag, I don't really have anything to offor on your clutch problem, except to say, 88 and up trucks used hydraulic. FWIW.
What I wanted to know was, will you please post some pictures of your 1 ton 4x4 dually? I'd sure appreciate it.
Post Whore
![]() Join Date: Feb 2000
I'm using a hydroboost master brake setup and hydraulic clutch out of a 1989 1 ton in my 69 4x4. Here are some pics. I used the engine from the same vehicle so I didn't have to find a way to attach the slave cylidner to the bellhousing. Someone either here or over at www.coloradok5.com has attached one to a normal bellhousing.
Since the brake setup is pretty heavy it was suggested that I reinforce the firewall. Buddy made me the aluminum plate that you see in the pics. The hydraulic clutch master is angled incorrectly so I had another friend make me the shim you see. This shim gets the master pointed correctly. Then I cut off the existing end on the master's rod, threaded it and added a clevis rod end to it. Took a bit of work to get the throw correct on the pedal so I had sufficient movement but no binding. Truck is ever so close to being ready to fire up, but hasn't been driven yet so I can't report on the improvement. ![]() ![]() This pic shows the brake rod end but the one on the clutch rod is the same type. ![]() Happy to help with any specific questions.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
Merciless Butcher
McCloud makes a setup with a hydraulic throwout bearing. Summit carries it. One of my Buddies used it in his 55' Belaire and it's slick. Way easier than trying to piece a system together. He is running an LS-1 and a Muncie. Check it out. You won't be dissapointed.
Your Bought And Sold....I Got Your Soul! |
The hydraulic clutch started in '85. I would just look for a parts truck.
I have heard of people with 4x4s having trouble with the internal setup.
1969 GMC K2500 ![]() 1996 Honda Accord 2007 Kawasaki KLR 650 |
I have a running hydraulic clutch on my 72 2x4 1/2ton. I is out of a 96 1/2 ton. Includes hyd throwout bearing. Trans does not accept a mechanical drive speedo setup. I was expecting a soft/easy clutch pedal---didn't get it. My 72Blazer 4x4 has a softer/easier clutch. I set up the clutch master cylinder on the inner side of the brake booster verses the outer. No Z bar to deal with. No sure I wouldn't trade for a 700R4.
