View Poll Results: which batter would you buy for off road | |||
sears diehard |
2 | 8.00% |
optima red top |
17 | 68.00% |
optima yellow top |
6 | 24.00% |
les schwab type |
0 | 0% |
Voters: 25. You may not vote on this poll |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
best battery for off road
I am looking at getting a new battery for my off road truck.. It has lights winch cb elecrtic fans and some other acc.. If you guys have any other suggestions other than whan what I listed please give me your input..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. Last edited by FRENCHBLUE72; 11-27-2004 at 02:13 PM. |
![]() Join Date: Feb 2001
I think the Sears are good. I would just prefer the Optima since it is jelly filled. I have a rd top and have never had any problems with it.
The oddest Todd around
Just remember to get the most cold cranking amps possible. I have a 925 in my truck. I'd have to crank on it for almost 6 hours straight to kill it, and I have accidentily left my electic fans on (toggle switch for now) for 8 hours and was still able to start the truck.
Got Light Emitting Diode?
with optima you can mount them sideways under your seat. i got a yellow top and love it. my alternator went out and it damaged the battery, so i took it in under warrenty and got a new one. FYI red top has a 2 year free replacement warrenty and the yellow top only has a one year
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's ![]() 1993 Cherokee work ride/weekend wheeler |
What was I thinking??
I had a Red top in my FJ-40 that I beat the hell out of with a winch and off road lights and such.
The only thing I would different now days is go to a Dual battery setup, I would use a Red top for starting and such and use a Yellow top for the winch and off road lights.
72 K5 that needs lots of parts.. 71 GMC 3/4 4x4 That doesn't need much which is a good thing I don't think I could aford another money pit... |
I have optima's in everything I own!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
PROJECT 7DEUCE
The wife suprised me and brought a red top home... Hell ya..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
![]() Join Date: Jan 2003
What a nice wife you have, Mine does the same thing sometimes..........
1972 Cheyenne K-30 6"lift {502 PROJECT} 1972 Cheyenne K-30 8"lift 454 450hp {Ol'Blue} 1972 Cheyenne K-20 Custom Stretch 6" lift 454 1972 Custom Deluxe K-20 4" lift 2007 GMC Crew Cab Diesel 6"lift {The Tow Rig 2017 Ford F-350 Crew Cab 6.7 6"lift (Wife's) 1977 El Camino SS Grandpa baught new 1986 K-30 Crew Cab 502 1955 Chevy 2-Door gasser 454 550hp{project} 1956 Chevy Bel-Air 2-Door hardtop 572 700hp 1979 Ford F-350 All Original 4x4 (Wife's) |
Since you listed yellowtop Optimas, I have no qualms about suggesting expensive batteries for off-road use:
![]() Hawker Odyssey batteries are vastly superior to the Optimas. Odysseys are a true, explosion-proof dry cell that "combine in one box the characteristics of two separate batteries. It can deep cycle (be recharged) as well as provide enormous cranking power." Basically, a it's a tough starting battery that can also be run down to zero charge with no harm just like batteries advertised as "deep cycle". The Odysseys only hurt the wallet. ![]() The Hawker Odysseys also have no tempermental recharge characteristics like the redtop Optimas. I have gone thru two Optima redtops because they were near completely discharged but would not come back, even for a battery shop. For 67-72 GM trucks, the Odyssey PC1200MJT is probably the best fit for OEM battery trays. And at the Optima yellowtop price. I hope this has been of help to all but your budget. ![]()
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup. |
The hawker batteries are awesome but higher in most places than a yellow top. I have one for my dragtruck project!
