Old 11-27-2004, 02:45 PM   #1
bigunde
Rusty Rockerfeller
Need a motor mounts question answered quick
just pulled the 350 out of my 70 getting ready to slide the 454 in and go to the parts store to get motor mounts and they are not the flat ones where the bolt comes up through the bottom.will the 350 mounts work?
bigunde is offline   Reply With Quote
Old 11-27-2004, 02:47 PM   #2
meathead95
computer illiterate
meathead95's Avatar
i have heard of people using the 350 mounts before.
72 2wd blazer
72 swb 4x4
meathead95 is offline   Reply With Quote
Old 11-27-2004, 03:23 PM   #3
gonebad2
Merciless Butcher
gonebad2's Avatar
454 may have too much torque for the 350 mounts.
Your Bought And Sold....I Got Your Soul!
gonebad2 is offline   Reply With Quote
Old 11-27-2004, 03:54 PM   #4
72 CustomCamper
huh ???
72 CustomCamper's Avatar
I have the 350 mounts holding down my 396. Also had them when I had the 6.2 Diesel in the truck...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 11-27-2004, 05:03 PM   #5
bigunde
Rusty Rockerfeller
does anyone make those lower rubber mounts that go under the frame mount
Old 11-27-2004, 08:06 PM   #6
Harold Shepard
They are being reproduced now but they are going for $75 a shot. TX firefight did a write -up on using the small block mounting pad with the big block stand. PM him to find out how he did it.
Harold Shepard is offline   Reply With Quote
Old 11-27-2004, 10:55 PM   #7
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
It's in the FAQ.
If you really want to use the underneath rubber parts too, use the upper half of a core support bushing. With a few seconds of grinding, it will work in place of the original underneath part.
My 454 was happy on the 350 mounts, no problem with them ripping apart.
Old 11-28-2004, 12:13 AM   #8
cochran63
cochran63's Avatar
I just recieved my solid mounts from moroso. 20 bucks and you'll never have to worry about them again.
Youth soon passes away, but immaturity can last a life time.
cochran63 is offline   Reply With Quote
Old 11-28-2004, 12:32 AM   #9
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I used the 350 mounts for the 454 but I have yet to hear it run or drive the damn truck so I cannot tell you if they will hold up or not..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 11-28-2004, 01:02 AM   #10
JDL
JDL's Avatar
I have had 350 mounts for About 18 years
72 Chevy short step side with 454 air and tilt.
72 nova project car
63 chevy II drag car
Agency Iowa
JDL is offline   Reply With Quote
