Old 11-27-2004, 07:25 PM   #1
patgizz
patgizz's Avatar
how bad did i mess up my truck?
i got a new battery for the burb today. long story short i bought the truck sans engine/trans but all wiring intact ready to plug in. its a 1990 and factory TBI. i installed a 355 with TBI. nothing in the harness is hacked up or tapped into save for a couple wires which i've fixed.
now my cables were in place tied to the tray from the factory, and i tossed the battery in and hooked it up. started checking things, and when i disconnected the battery i realized i had hooked it up backwards(+ to -, - to +). it cranks, the turn signsls and backup lamps work, power windows work, wipers work, seatbelt warning light works, gauges move when i turn the key to run. the fuel pump, head and tail lights, interior lights, heater, gauge lights are not working and there is no spark.
i'm hoping maybe i just blew one of the breakers? is there any other stuff i could have fried?
patgizz is offline   Reply With Quote
Old 11-27-2004, 07:43 PM   #2
Russell
Professional Grade
Russell's Avatar
Aye, I'd guess you fried the ECM
Check all your fuses / fusible links?
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 11-27-2004, 08:22 PM   #3
dons454s
dons454s's Avatar
I would also check any fusable links
dons454s is offline   Reply With Quote
