Old 11-27-2004, 08:31 PM   #1
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
What are these???
Like the title says what are these doo dads located in the upper firewall area???
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 11-27-2004, 08:33 PM   #2
Sweet72
Sweet72's Avatar
Horn relay, and TCS time delay relay.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 11-27-2004, 09:58 PM   #3
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
i know what SWB means but what is a TCS time delay relay ??? Traction Ccontrol Sensor
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
Old 11-27-2004, 10:09 PM   #4
FRENCHBLUE72
PROJECT 7DEUCE
I will take a shot with turnsignal controll switch or turnsignal cancelling switch..
MEMBER #6377
Project "7DEUCE"
Old 11-27-2004, 10:15 PM   #5
jamis
F.A.S.T. president
jamis's Avatar
Electro-magnetic multiplex demodulator for the 64-megahertz sound wave generator circuit and its counter part for the forward light duplicating night guidance system. Also know in some parts of this world as a horn and/or head light relay....or none of these....I dont think I'm helping in any way so I must say goodnight
F.A.S.T. President and Founder
Fabricators for the Advancement of Sawsall Technology
"A fear of the Sawsall is a sign of retarded sexual and emotional maturity." ~Sigmund Freud, "General Introduction to Psychoanalysis"
jamis is offline   Reply With Quote
Old 11-27-2004, 10:27 PM   #6
neonlarry
neonlarry's Avatar
Transmission Controlled Spark. The relay controls power to the vacuum solenoid on the right side of the intake manifold by the carb.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 11-27-2004, 10:32 PM   #7
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Were they on the inside or under the hood? If under the dash on the firewall, it's a horn relay.
If on the firewall under the hood.....well, I still haven't figured that one out yet. On my 70 K10, it had one ignition-on wire running to it (pink), and 4 wires running out. Two went to an A/C compressor type connector (blue/black), one red with a spade, and I can't remember the other one. Regardless, the thing had only one input wire to it, the pinkl one. And that was originally tapped off of the radio power wire.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 11-28-2004, 12:28 AM   #8
FRENCHBLUE72
PROJECT 7DEUCE
So on a new wiring harness are these part of the system still or do you unbolt and throw these items away? Glock bot units are inside the cab..
MEMBER #6377
Project "7DEUCE"
Old 11-28-2004, 12:52 AM   #9
Harold Shepard
They are th transister control spark relays- when you order your new harness you need to specify if you want to keep it (depends on if the solinoid is still attached to the pass. side intake manifold. It should have a plug that looks like A/c plug -2 flats and nipplies for vaccumn on each end. Hope this helps.
Harold Shepard is offline   Reply With Quote
Old 11-28-2004, 12:54 AM   #10
FRENCHBLUE72
PROJECT 7DEUCE
I swapped in a 454-th400 combo and will order a new harness for that set-up from what I understand I can remove and throw away these two items correct?
MEMBER #6377
Project "7DEUCE"
Old 11-28-2004, 01:01 AM   #11
Harold Shepard
trash them
