Under construction!
Well, I'll be picking up a LWB 78' C10 frame w/ surface rust next week. Go figure, rust in California.
![]() Should I have the frame sandblasted and primed? I've never dealt w/ rust before, so any advice/tips would be appreciated. When said and done, I want the frame to be smooth like the exterior sheetmetal. ![]() Also, does anyone have an article explaining how exactly to shorten a LWB frame and make it a SWB? If not, I'll be building a long bed. Which is fine w/ me because they are more rare in the custom truck scene. Thanks. ![]()
2001 Silverado bagged on 22's. *Sold* |
Happy to be here
![]() Join Date: Mar 2000
glock35ipsc did an awesome article on how he did his frame. Of course it helps that he has a shop full of the right tools and knows how to weld like a pro. Take a look here-How to shorten a LWB frame
Keep in mind that this is for a 68 frame so you will have to adjust some of the deminsions.... ![]() |
i hear that you can brush por-15 on and it sticks better where there is rust its supposed to be pretty tough stuff too
#4 | |
Under construction!
![]() Thanks for the link, Ken. ![]()
Under construction!
Just got done viewing that link. WOW, is all I can say. Talk about a top notch job!
![]() BTW, my new frame looks no worse (As far as rust goes) than his. Just to give you guys an idea of what I'm up against. ![]()
2001 Silverado bagged on 22's. *Sold* Last edited by BaggedC10; 11-28-2004 at 12:58 AM. |
yeller
Dan, If I were you I would have the frame sandblasted. IMO, that is the best and most economical way to get rid of all the rust. I had my frame sandblasted, eopxied, and painted all by the same shop. As long as your frame isn't pitted terribly bad, it should turn out real nice. Here is a link to some on my site as well as a pic just to show you how nice it turned out...
http://www.73-87.com/my_truck/mytruck.htm
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
Under construction!
Your chassis is what started my passion for a "perfect" chassis, Jeff. My backhalfed frame was sandblasted before being powdercoated but it wasn't rusted. That's my main reason for asking this question. To see what I should expect.
To shorten the LWB frame take 14" out of the middle, come 1.5" off the rear cab mounts, and 1.5" off where the first bed crossmember is. That will give you 14" between. Then another 4" (I think, cant find my sheet right now) will have to come off the end of the frame. I still have the pieces of the frame, so I will measure it after it gets light out!
One day..I'll write it up for jeff and send him the pics for his site. Been way to busy trying to get it somewhat reliable so I can enjoy it. ![]() Bagged.....Why didnt you like the powdercoating? I"m fixing to get a SWB frame to start on for mine and was thinking of having in powdercoated when the time came. I dont know anyone who has done it, so just looking for some opinions.
Paul '78 GMC Serria 15 Heavy Half. 361/NV3500/3.73. Former LWB NV3500 swap Trailing arm swap '98 ECSB Z71 daily driver -traded ![]() '03 burb. Family cruiser http://upstategmtrucks.com/ Last edited by bluex; 11-29-2004 at 07:05 AM. |
#9 | |
Under construction!
Thanks for those "rough" numbers. ![]() Powdercoat is nice but I prefer paint. It's easier to repair and in many cases, more durable from my experience. My old frame was the foundation for a show truck. This time around, my truck may serve as my daily driver. More incentive to have it painted because ease of repair. ![]()
#10 | |
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
BTW, this is my opinion, but don't get it sandblasted until you are ready to paint it. Do everything you want to do to it now get it completely ready to put back together with whatever you want and then get it blasted and painted. BTW, I blasted mine then POR15'd it, waited 30 minutes and put Chassis black on it. POR15 only ![]() GLOSS Black over POR15. ![]() ![]() http://www.captkaoscustoms.com/images/rolling_bck.jpg http://www.captkaoscustoms.com/images/rolling_frt.jpg http://www.captkaoscustoms.com/images/rolling_side.jpg
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
#11 | |
Cool, I'm planning on mine being just a fair weather cruiser/show someday and was thinking powdercoat was gonna be nice b/c its hard to break/scratch. The middle numbers are exact. I know b/c I measured them at least 4 times on 3 different days. ![]()
Paul '78 GMC Serria 15 Heavy Half. 361/NV3500/3.73. Former LWB NV3500 swap Trailing arm swap '98 ECSB Z71 daily driver -traded ![]() '03 burb. Family cruiser http://upstategmtrucks.com/ |
hey how much does the frame weigh with nothing on it thanks
#13 |
Professional Grade
It'll be fairly heavy... They are fairly thick peices of steel. I'd guess 2 - 4 hundred lbs...
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
#14 |
how much does a shortbed weigh could i lift it off with 2 people?
#15 | |
Under construction!
Not very much. I would guess around 175-pounds or so. Nothing one person can't move w/o some grunt. ![]() Two people can remove a SWB bed w/ the tailgate removed but I would recommend 3 people. ![]()
#16 | |
Under construction!
Thanks for the advice, Chris. ![]() I was going to install my ART parallel 4-link but have decided to go w/ the KP Components bolt-on 4-link w/ cantilever attatchment. As a result, the only fabrication will be installing a fuel cell. I'll install the 4-link/attatchment after having the frame painted. Just have to be careful..... ![]()
#17 |
i must have missed it, what happened to your backhalved frame?
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works '05 1500 Crew Cab RIP '84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker '80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's |
#18 | |
its just $$$$$
#19 | |
Under construction!
I just feel the need for change.....as usual. ![]() Actually, I want a more "daily driver" friendly vehicle. I don't doubt that my truck would have been reliable and trouble-free but I would worry about it 24/7. It was becoming too nice to drive daily. This truck will be a daily driven show truck and will see occasional use (Trip to Home Depot, etc.). ![]()
#20 |
so did you sell the backhalved frame or you saving it for later?
#21 | |
#22 | |
Under construction!
I still have the balls to bag' it! :p Low 84---I sold the frame already. ![]()
