Old 11-27-2004, 10:23 PM   #1
Mint68
Mint68's Avatar
DANA 44 Front axle problem
Does anyone know if a dana 44 front axle has c-locks holding the axles in? If so, how do you remove the front axle. If not, will the axle just pull out? It doesn't have a lock screw holding the pinion shaft in, it is a roll pin, or what looks to be a roll pin. Has anyone pulled the axles out? Help needed!
Mint68 is offline   Reply With Quote
Old 11-28-2004, 12:07 AM   #2
'71c204x4454
'71k204x4454
I was able to just pull mine out. Sometimes it takes a good tug. But they should come right out.
1971 K20 4x4
1964 buick skylark convertible
'71c204x4454 is offline   Reply With Quote
Old 11-28-2004, 03:06 AM   #3
1969 GMC
1969 GMC's Avatar
dana 44 fronts are full floaters, so there is no c-clip and yeah, it should come right on out.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
