11-27-2004, 10:26 PM | #1 |
DANA 44 Front axle problem
Does anyone know if a dana 44 front axle has c-locks holding the axles in? If so, how do you remove the front axle. If not, will the axle just pull out? It doesn't have a lock screw holding the pinion shaft in, it is a roll pin, or what looks to be a roll pin. Has anyone pulled the axles out? Help needed!
11-27-2004, 11:14 PM | #2 |
Majician
The axleshafts are not held by c-clips as the rear axles are. To remove them you have to take off the hub/rotor assembly and then they just slide out.
11-28-2004, 01:39 AM | #3 |
huh ???
Don't forget to remove the spindle...
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's "I am a bomb technician. If you see me running try to keep up!" |
11-28-2004, 03:06 PM | #4 |
Majician
Yep, I forgot to mention the spindle. The spindle can be a PITA to remove. I have a slide hammer type puller that I use to pull it off. AutoZone may rent the pullers.
