Old 11-28-2004, 11:50 AM   #1
jamis
F.A.S.T. president
jamis's Avatar
taking 68LSS1's dare,warning to the faint hearted
Well this is the point of no return, A follow up to this post
http://67-72chevytrucks.com/vboard/s....php3?t=128303
F.A.S.T. President and Founder
Fabricators for the Advancement of Sawsall Technology
"A fear of the Sawsall is a sign of retarded sexual and emotional maturity." ~Sigmund Freud, "General Introduction to Psychoanalysis"
jamis is offline   Reply With Quote
Old 11-28-2004, 11:59 AM   #2
johnje
johnje's Avatar
It'll be pimp on a sunny day. My M37 (mil truck) has no top, I've been throwing fits the last two summers 'cause it's not together yet.
John
'67 M37B1
'67 Galaxie Convertible
'67 GMC Truck
johnje is offline   Reply With Quote
Old 11-28-2004, 12:27 PM   #3
gr8scott51
gr8scott51's Avatar
cool!
Silence is golden, duct tape is silver. - Scott
gr8scott51 is offline   Reply With Quote
Old 11-28-2004, 12:33 PM   #4
Randy70C-10
Randy70C-10's Avatar
Wow, you really did it!
Randy70C-10 is offline   Reply With Quote
Old 11-28-2004, 12:48 PM   #5
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Hey your roof fell off..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 11-28-2004, 03:13 PM   #6
68LSS1
68LSS1's Avatar
Now that's what I like to see! You get that a little farther along and I'm gonna have to come check it out.
'68 Short Step
LS1/T56, Hydratech, Fatman Fabrications Stage III, Baer, Hot Rods to Hell, US Body, S&W, etc
68LSS1 is offline   Reply With Quote
Old 11-28-2004, 04:56 PM   #7
Brainchild
Still drivin' a Rat Rod
Brainchild's Avatar
You did it,you flipped your lid
Looks good.I like it,but like I said it's not practical around here.
Rusty Member #13872
Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#*
71 GMC LWB
49 Chevy
85 Chevy G20
Check out my website
Brainchild is offline   Reply With Quote
Old 11-28-2004, 05:21 PM   #8
N2TRUX
Happy to be here
N2TRUX's Avatar
It's only metal, right. I say don't be skeert, be a man and cut that classic truck up...
I assume you braced the cab "before" you cut the roof off
Old 11-28-2004, 06:36 PM   #9
Rusty Rider
Rusty Rider's Avatar
are you going to finish the truck with no top or make it an option to reinstall, like the corrvet hard top convertible?
72 long fleet (WIP)
00 Astro every day
Rusty Rider is offline   Reply With Quote
Old 11-28-2004, 08:36 PM   #10
jamis
F.A.S.T. president
jamis's Avatar
I would like to build a Carson top later on, but it will stay topless for a while. The metal top is just to heavy to work with. Its only going to be used in local cruises and taking a spin to the beach any way.
Old 11-28-2004, 08:43 PM   #11
71Longbed
Not Mine But A beauty
71Longbed's Avatar
i dare you to not chop the top 3 inches +
68 Chevy Shortbed 454/400
2000 Chevrolet Camaro SS 6spd
2011 Silverado 5.3 6spd auto
71Longbed is offline   Reply With Quote
Old 11-28-2004, 09:10 PM   #12
jamis
F.A.S.T. president
jamis's Avatar
I would if I could find someone to cut the glass. Any body no the right way to lay back the pillers?
Old 11-29-2004, 01:55 AM   #13
sniper2321
sniper2321's Avatar
You wil need to cut the doors first. Cut it at thetop of the A pillar's for the vent window. Next measure up the back of the window frame 2" then make the cut. Take out the amount you want to chop from the roof I like 2 - 2 1/2" not too dramtic. Now you will weld back the top piece of the win frame to the piece that you measure up for the cut in the back use spot weld. Now you will need a second pair of hands. Use two straight edges. Put one on the door flat across the top then use the other to form the angle of the A pillar window frame to the top of the window frame that you welded back. This will give you a refrence gage to make a pie cut a the bottom of the A pillar win frame. Use a torch to heat it up and then bend it back with help to make sure it is straight to line it up then spot weld it. Do this to both doors. Now with the windsheld in make the same pie cuts in the A pillar window frame have four buds on hand for this as they will have to heat both sides at the same time and then the other two will haveto pull down on the a frame pillar's to meet up with the new door frame angles. Now weld it up after you check it to be equal and straight. You sould be done in a day or 2. Hope this helps if need be I hope to be going to Eds soon and I could show you in more detail. Let me know.
sniper2321 is offline   Reply With Quote
Old 11-29-2004, 03:02 AM   #14
68LSS1
68LSS1's Avatar
Nice post sniper2321, I'm getting jealous. I wanted mine to be a daily driver but... Next project will have to be a clean, bagged, chopped, convertible top.
'68 Short Step
Old 11-29-2004, 08:03 AM   #15
jamis
F.A.S.T. president
jamis's Avatar
Thanks sniper, I was uncertain about the pie cut. Would you say the pie cut has to be 1/2 or 3/4 way into the pillar? Its going topless so it dont have vent window pillar to worry about.
Old 11-30-2004, 01:00 AM   #16
sniper2321
sniper2321's Avatar
I like to use the door as a refrence to guide me as to how deep the pie cut needs to be. Then i transfer that to the window A pillar which leaves me with the least amount of welding and body work. I all so like to leave the vent windows with the pillars for support of the windsheld frame as it does not have the built in support as the Jimmy/ Blazers do.
Old 11-30-2004, 11:34 AM   #17
jamis
F.A.S.T. president
jamis's Avatar
Yep, there is very little support left as far as roll over protection. I would like to ad a roll bar to the back, but the would take away from the look I want. I going to get something to fit and slide down the inside of the pillers for extra support and tie it in some how. I still may put in a short roll bar with two small hoops just behind the driver and passenger, kind of what they use in the cobra replicas.
Old 11-30-2004, 02:05 PM   #18
cojnit
Nothing clever
cojnit's Avatar
just drop it so low that it will be almost impossible to flip!
Got "the Midas Touch!"
cojnit is offline   Reply With Quote
Old 11-30-2004, 08:06 PM   #19
72CSTC5
72CSTC5's Avatar
I agree with cojnit drop it all the way down and you will never have to worry about rolling over. Would like to see pics of that when you are done. I've often thought of chopping the windshield down on my 2wd Blazer, but I don't know. Might want to put the top back on one day.
72CSTC5 is offline   Reply With Quote
