11-28-2004, 02:35 PM | #1 |
HEI plug wires
What are you guys using for plug wires (stock) on the HEI if converted. I bought a set of 73 truck wires and they all have 90 degree ends on both ends. This is my first Chevy as I am a Pontiac guy. I am not impressed with way the wires fit and route.
11-28-2004, 02:41 PM | #2 |
"Ochre Ogre"
1976 Corvette. That is the first year with HEI and it still used the rams horn exhaust manifolds.
Bowtie Truck Stop Inc. Mid-West GM Truck Restoration Parts Supplier Your Key Parts, Auto Metal Direct, Dynacorn, and Goodmark dealer. like us @ www.facebook.com/BowtieTruckStop 1971 C-10 Suburban (Ochre) 1971 K-10 Suburban (Ochre) 1972 C-10 Suburban (Ochre) 1972 K-20 Suburban (Yellow- that just aint right!) Springfield, Minnesota 56087 |
11-28-2004, 02:44 PM | #3 |
what he said, that's what I run and they fit and function well...
'72 short step, 350, 700R4, tilt, ps, pdb, a/c, lowered coils, etc., other work in progress... San Diego, CA 72 Stepside Project |
11-28-2004, 02:51 PM | #4 |
"Ochre Ogre"
FYI, 73 trucks were still points style ignitions and the exhaust manifolds were log style designed for the wires to come from above. That is why you don't like the routing. They are all too short for rams horn manifolds where the wires go around the back side and come up from below the manifold.
11-28-2004, 03:00 PM | #5 |
How about MSD Universal set like 3118. They have multi angle boot on the plug and you cut to fit and install the 90 boot for the HEI. They are $60 at Autozone.com and come with a crimping/cutting tool.
I see the 'vette wires as p/n 4118 at $21.99 and the Bosch at $29.99. |
11-28-2004, 03:35 PM | #6 |
For a DD, there's nuthin' wrong with stock ignition wires if checked and replaced near annually. Good up front prices, too. And most of the spiral wound perf wires are actually little better than the stock wires, except that they don't easily deteriorate from their new condition. I've only found one spark plug wire with high performance conductivity, wire longevity, heat resistant jackets, and RFI suppression. They're made in USA by Magnecor.
Read their FAQ and other explanations of how the high performance ignition wire "industry" is smoke and mirror marketing. Eye opening. I just bought a stock set for my K10 with 350 and Rams Horn manifolds for $90 thru Magnecor's direct sales. Expensive, but worth it IMHO. I expect they carry the version for a 76 Vette w/Rams Horn manifolds.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup. Last edited by 4x4Poet; 11-28-2004 at 03:38 PM. |
11-28-2004, 03:58 PM | #7 |
its all about the +6 inches
Replacing wires every year is just a little bit on the over kill side. (even the $10 auto zone ones last longer than that)
If your wires are not cut/burned/pinched/dry rotted, then there is no reason why you shouldn't be able to get 5 years out of them at or damn near new wire efficiency. (asuming a good HEI set up an plugs not gapped excesivly) |
11-28-2004, 04:05 PM | #8 |
Watch out for your cornhole !
I personally, only use Delco plug wires on GM vehicles.
I tend to get about 60 to 80 thousand miles average out of a set. That's 3 to 4 years for me.
11-28-2004, 04:14 PM | #9 |
"Trucks with Class"
I like to run BB HEI wires on my SB trucks, because they have straight ends. You can run them neatly over the valve covers. They don't get dirty & oily like those that run down under and it is easy to keep an eye on them and they clean up easy.
Which plug ends are on those Vette wires? |
11-28-2004, 04:16 PM | #10 | |
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup. |
11-28-2004, 04:18 PM | #11 |
Still drivin' a Rat Rod
I'm just running some cheapos from Orielly's.Been 2 years and I don't see a problem yet.
Rusty Member #13872 Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#* 71 GMC LWB 49 Chevy 85 Chevy G20 Check out my website |
11-28-2004, 07:49 PM | #12 |
"Ochre Ogre"
PICKMUP, I am 99.9% sure they are 90 degree boots.
11-28-2004, 09:11 PM | #13 |
76 Vette wires from Napa. Nothing special, but they work at a good price!
Nelson 1970 C10 350 Auto. A/C not Working |
11-29-2004, 09:28 AM | #14 |
Great tip on the 'vette wires
I bought some damned expensive MSD plugs so that I could get straight ends at the block. They were $40 if I recall correctly. Will be doing the 'vette plugs next time!!!! |
11-29-2004, 09:53 PM | #15 |
I used a set from a 454 mid-late 70s motorhome all straight boot. easy to route and loom.
1970 GMC K15 - Canadian built 2nd Owner truck 68k miles 2014 Denali 1500 6.2L |
