i love summertime
atf in a transfercase? also rear end and xcase id pls
has anyone ever heard of using atf in a transfer case? my dad just bought a 72 chevy 3/4 ton 4x4 and is just going over everything...he said that the manual says to use atf in certain transfer cases...anyways the code on his xcase is:
1 C-99404 W the 1 and W are in those places, above the C and below the 9 Also just out curious to the ratio in the rear end, the code off it is: 3934635 i might have a pic of it here if that helps thanks, Derek
1967 shortbox stepside Chevy, 365 hp 327, th400. GLOVE BOX LIGHTS FORSALE, click link for info http://67-72chevytrucks.com/vboard/s...d.php?t=273724 |
i love summertime
for some reason the xcase code all goes to the left margin, like i said above the w is below the 9...im sure this doesnt make any difference but i just dont want to miss anything
thanks again, Derek
"Trucks with Class"
![]() Join Date: Jul 2000
I think our TCs use 90W gear oil. Synthetic might even be better. ATF may have been used in some later model applications.
If you run 90W or equivilent and ATF shows up in your TC, it shows you that the seal went out in your adaptor between trans & TC...a common problem...trans gets low & TC gets over full. Always change that seal if you have one apart. |
Where'd you find the numbers on the rear end? I have the same rear end in my truck and I never found the numbers yet. Oh that is one of the Corporate(Eaton) rear ends, Chevrolet used those in trucks from like 47-72.
RJD 1984 Chevrolet C30 welding truck 454/SM465 1977 GMC C15 pickup 350/TH350 1970 Chevrolet C20 pickup 350/TH400 1970 Chevrolet K20 Suburban 454/TH350 1969 GMC 8500 478M V6/5 spd winch truck |
As long as the 72 still has the original NP205 transfer case, the Chevrolet Service manual states:
TRANSFER CASE: "...Use SAE 'GL-5' gear lubricant, and follow the 'Gear Lubricant Viscosity Table' for proper viscosity gear lubricant to be used during vehicle operation." REAR AXLES: "...when necessary, refill to level of filler plug hole using 'GL-5' gear lubricant as shown in the 'Gear Lubricant Viscosity Table.'" So, it's GL-5 all the way. For manual trans too. Now to viscosity: Gear Lubricant Viscosity Table Below 10ºF: SAE 80 Up to 100ºF: SAE 90 Above 100ºF consistently: SAE 140 I use Amsoil synthetic GL-5 90W in both my NP205s and in all my pumpkins. In my manual trans, I use Redline's synthetic GL-5 MT90 for the additives they use to make the synchros work not too stiff, not too loose. The axle you pictured looks like an Eaton H052. It probably has 4.11 gears. If you remove the diff cover to change the oil, count the ring & pinion gear teeth and calculate the ratio.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup. Last edited by 4x4Poet; 11-28-2004 at 04:53 PM. |
i love summertime
thanks guys
Derek, on both of the Eaton centersections I have, the gear ratio is stamped into them on the side. Its actually the # of teeth on the ring and pinion. 7/36 is stamped on one (5.14) and I forget what the 4.57 one says.
I am guessing 4.11 should be 9/37
1969 GMC K2500 ![]() 1996 Honda Accord 2007 Kawasaki KLR 650 |
