11-28-2004, 09:53 PM | #1 |
Brake Drum making scraping noise
I adjusted the brakes today and after I was done I noticed that the pass side is making a scraping noise. I am not sure if it was there before I started. Did I adjust to far?
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 |
11-28-2004, 10:44 PM | #2 |
If the drums are true and not warped you probably adjusted them too far. I always make adjustments so the shoes are close but not scraping and then drive in reverse and apply the brakes and the self adjusters do the final adjusting
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction. |
11-29-2004, 12:33 AM | #3 |
After listening to them pass side a nit I think it it is warped. I am going to get new shoes and it turned tomorrow.
11-29-2004, 02:51 AM | #4 |
I drove it around some tonight and the pass side is warped.
11-29-2004, 01:37 PM | #5 |
It's a catastrophic success.
Did you pull the drum and inspect before you adjusted?Nothing like adjusting out a worn out shoe.
11-29-2004, 09:52 PM | #6 |
Brake Noise
Since you have not replaced your brakes, my reply is not your problem. However if you do replace the shoes, pay attention to the springs and the rod that goes thru the spring. Some one help mw with the proper name for the spring and rod. If you buy a brake spring kit from local auto parts store, it will most likely come with sprongs and rods for 1/2 ton and 3/4 ton brakes. If you install the 3/4 ton rods on 1/2 ton brake shoes, the ends of the rods will rub the drums. This noise is hard to find untill you have been there and done it.
