Old 11-28-2004, 11:02 PM   #1
Chevelle454
Chevelle454's Avatar
Starter problem...
When my truck('72, 350) has been sitting for a while and the motor is cold, it will turn over and start just fine. But no matter how long I let it run for, even just 10 seconds and then I shut it off, when I go to start it back up the motor will kick back and backfire and the starter will skip and grind on the flywheel. I have the starter shimmed good.
What would cause it to do this? I know the timing isn't set, it's right around 0 degrees. But would that matter for hot vs. cold engine starting?
Thanks in advance,
-Scott
1972 C10
1972 C20
Chevelle454 is offline   Reply With Quote
Old 11-29-2004, 08:03 AM   #2
Chevelle454
ttt
1972 C10
1972 C20
Old 11-29-2004, 01:15 PM   #3
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
timing and old gasoline.
sneakysnake is offline   Reply With Quote
