Before and After
Choke decisions
I will be building a new small block, and just wondering about the choke. I live in Canada and the truck will be driven only in the summer. The exhisting quadrajet has the choke that has the bimetalic spring built in the intake maifold. I will be purchasing the RPM performer and a carb from Edelbrock.
Does the choke mechanism have any effect on how the carb functions normally? Is the electric choke the most common? ![]()
Not Grandpa's C-20 anymore... 383 Stroker 425HP, 485Ft/Lbs Lowered 3.5" Front / 5" Rear 66,000 miles. Alberta, CANADA |
The stock bimetallic spring choke setup works somewhat but the electric chokes work better. The stock chokes don't warm up fast enough in cold weather and stay on longer than they should. I would recommend the electric choke as it will open up faster and is more reliable.
Jim |
Give up on both of them, and put in a manual choke
That's what I have, a manual choke. It's cheap theft protection. I can keep mine running without it closed (it takes some work. My choke cable wasn't working right for the first 2 weeks of winter so I learned the hard way) but I doubt anyone who has never even heard of a manual choke will get my truck out of my driveway.
Brian 72 C10 longbed 350/th400 Let the world change you and you will change the world. |
I installed an electric choke on mine but I don't think it's working. Is it correct to run a wire from the choke to the UNFUSED spot on your fuse box?? I ahve mine hooked up this way, but it won't run the idle up when it's cold at all
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
#6 | |
Progress = 0%
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra |
Before and After
What is involved in the setup of an electric choke?
#8 | |
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup. |
#9 | |
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
#10 | |
To add to jhow66's reply, we use the factory setup for the choke on several of our trucks and they do work. It seems that they need a lot of attention and adjustment to get them to work right. They work better if the engine is equipped with the thermactor setup and heat riser. (We don't have either one on any of our trucks).
Engine temperature is important so a 195 degree thermostat is desireable. It makes a difference if the exhaust crossover passage is clean and flows well. The electric choke works better under a variety of conditions so that would be the one that I would recommend. A manual choke will work but they can have problems also. Jim |
Just don't forget to disengage the manual choke before you go driving all over the place.
#13 |
I have the same setup, it's called a divorced choke. When the engine's cold, the spring contracts(winds up) and closes the choke. When the engine starts to warm up, it expands(opens up) and the choke opens till the engine is at operating temp. and the choke should be open all the way. That's how mine is and I haven't had any problems with it.
RJD 1984 Chevrolet C30 welding truck 454/SM465 1977 GMC C15 pickup 350/TH350 1970 Chevrolet C20 pickup 350/TH400 1970 Chevrolet K20 Suburban 454/TH350 1969 GMC 8500 478M V6/5 spd winch truck |
#14 |
Sisyphus was my mentor!
![]() Join Date: Sep 2002
I converted my q-jet to an electric choke & it rocks. I got the parts at the bone yard. I SEEM to remember that the late 70ies/very early 80ies have what u need. I will admit that it is a particularly fussy adjustment, but when its good is done like dinner. & ya, go to a fused ignition power source.
passthebuck ![]() #5642 -TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4. -a 2013 Honda Civic as my "sensible" car |
#15 |
Its Magically Delicious
i have a divorced choke as well .. is it possible to attach a manual choke cable to my fast idle cam and remove the whole spring setup ..
71 C10 LWB 350sbc -TH350 12 bolt 3.42 Posi Of all my favorite things to do, The utmost is to have a brew. My love grows for my foamy friend, with each thirst-quenching elbow bend. Beer so frosty, smooth, and cold it's paradise pure liquid gold. Yes beer means many things to me that's all for now cus I gotta pee. |
#16 |
71-Longbed - I bought a "HELP" kit from one of the chain parts stores (A-zone or Advance - don't remember) and it comes with the choke cable, a bracket to mount the knob inside, and a clamp that attaches to the choke butterfly rod. I had to remove the bi-metallic spring on the side of the carb (Q-jet), and the housing the spring was it. Just a couple of screws...
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current 1969 K20 - V8, 465, 221, Eaton, D44 2012-current Nothin' but drums on all 4 corners! past horses in the stable 72 C10-short step (97-02), 68 C10-long fleet (06-12) |
#17 |
do you happen to know how long the choke cable has to be ??? do you have any pics ??? thanks a bunch
