11-29-2004, 02:14 AM | #1 |
Majician
Is this the correct exhaust manifold?
Hey guys, I'm new to the 67-72 trucks and don't know squat about them, but now I need to learn. Is this pic of a factory passenger side exhaust manifold or has it been swapped out? It looks different than the driver side manifold.
11-29-2004, 02:17 AM | #2 |
Looks like it's been swapped out. Both sides should match, and they dump in the center, not at the end. They resemble a ram's horns, hence the name, "ram's horn exhaust manifold."
Should look like this: |
11-29-2004, 02:20 AM | #3 |
Majician
Ok, thanks. I was looking at a pre-bent exhaust system in a catalog and something just didn't look right. Thanks for the quick reply.
11-29-2004, 09:33 PM | #4 |
The pic of the manifold above is for cars typically....truck manifolds for 2wd trucks are ram horns with a turned back end. I'll post a pic of typical 72 2wd type. Striaght down ram horns are used a 4x4's.
The car type above is used on motors that have alternator brackets attached to the exhaust manifold....some 67 trucks used that type manifold..but still in a truck thats 2wd is should angle back. 72 style truck 2wd pictured here.
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. |
11-29-2004, 11:27 PM | #5 |
My other Love
that exhaust manifold on the passenger is off a late 80s v8, if you cared
Castlegar B.C.The great white North (Canada Eh!) Hooter_5@hotmail.com First generation Monte Carlo club pictures of my life |
11-30-2004, 02:12 AM | #6 |
Whoops, my bad, Rod is right, that's a car manifold I posted. He posted the correct truck ones. Was the only "rams horn manifold" that came up on Google Image Search, and my brain let that one slip by.
11-30-2004, 06:23 AM | #7 |
Majician
This is what the drivers side manifold looks like, pointing straight down. The motor looks like a mis-match of parts, but has the older style accesories on the front. Damn PO... |
