Old 11-29-2004, 09:43 AM   #1
ChevyDude
New battery leads??? Who sells them?
Where can a guy get the POSITIVE and NEGATIVE leads that are made for a 71' or 72'? Auto Parts store....Chevy Parts counter??? Someone knows....lil' help please.
Alex
1971 Lil' Red 350 SBC 700R4
ChevyDude is offline   Reply With Quote
Old 11-29-2004, 10:07 AM   #2
spencra
This, is my BOOMSTICK!
spencra's Avatar
I bought new ones at Advance Auto.I replaced the whole wiring terminals and all for I think just under $20. Know the lengths though. Unless you are looking for factory because they didn't have the parts listed in their computer so I just estimated the lengths and thankfully I hit it dead on.
Hope that is helpful.
Larry
Got rid of my projects for now.
1980 Jeep CJ7
1998 Nissan Sentra (my car)
2001 Toyota Sienna (wife's, of course)
spencra is offline   Reply With Quote
Old 11-29-2004, 10:11 AM   #3
71Rat
ran out of money
71Rat's Avatar
i know walmart sells all different size ones, so if you know your size go there and they should have them, well at least the walmart by me has them.
Hope this helps
Rat
Modify everything, leave nothing alone!~
71Rat is offline   Reply With Quote
Old 11-29-2004, 11:15 AM   #4
ChevyDude
Ok guys bought this truck in an "Apart" state......How long is the "P", and How long is the "N"......it's for a 71' 2wd 350 engine.
Thanks guys!
Alex
Old 11-29-2004, 11:27 AM   #5
spencra
spencra's Avatar
I don't know if this will help but I have a 327 2wd and the P term was like 42" and the N term was I believe 31". I don't think that the set-up is much different (I could be wrong though) but if you have to just remove them and bring them with you. They are pretty east to get off.
Larry
1980 Jeep CJ7
Old 11-29-2004, 11:28 AM   #6
ChevyDude
Thanks Larry!
Alex
Old 11-29-2004, 11:30 AM   #7
spencra
spencra's Avatar
No Problem. Oh, I just noticed that you said that your truck was apart. I guess that you don't have old ones to compare them to. I do have a 79 chevy with a 350 in it. I could check on that one to see if there is any difference.
Larry
1980 Jeep CJ7
Old 11-29-2004, 11:37 AM   #8
ChevyDude
Larry, I just searched Advance Auto's site and the answer to the puzzle was there, except they are side posts, I need Top posts for my Red Top Optima...but the lenghts were there.
Battery Cables
For vehicle: 1971 CHEVROLET C10 PICKUP 4 Barrel V8 5.7 Liter Carbureted
Description Availability * Price Buy
Autocraft Cables A2120435
Negative Cable; Black; 4 Gauge; 35"; 1 Lead Find in a store Ships in 1 day
Weight: 0.7 lbs. $6.48
Autocraft Cables A2741045
Positive Cable; Side Post Term.; 45"; 4 Gauge; Red; 1 Lead Find in a store Ships in 1 day
Weight: 0.9 lbs. $7.28
Alex
Old 11-29-2004, 11:40 AM   #9
spencra
spencra's Avatar
Ok ChevyDude, I looked at the 350 and the P should be fine at 42" (but you could probably go a little longer). The N however is a slightly different setup. On my 67's 327 it is ground to the water pump bolt whereas in the 79's 350 is bolted to the alternator. In the 79 the N cable was like 36" long but it had alot of slack in it. I would have definately gone with a slightly shorter cable.
Larry
1980 Jeep CJ7
Old 11-29-2004, 11:42 AM   #10
spencra
spencra's Avatar
Great! you gotta love the computer. I'm not sure if there is much difference in length with the side posts.
Larry
1980 Jeep CJ7
Old 11-29-2004, 12:49 PM   #11
neonlarry
neonlarry's Avatar
?? I need top posts for my red top Optima. Need or want? All of my red tops have both top and side connections.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 11-29-2004, 01:39 PM   #12
ChevyDude
Not on this Red Top...only has post connections.
Alex
