Old 11-29-2004, 10:40 AM   #1
Frankd
help with tilt column
I have a 78 k-10 with a tilt column, it has some dlop in it(dosen't lock tight) is there a way to adjust it without rebuilding the whole column?
72 c-10
81 c-30
67 c-10 just sittin in the woods)
70 C-10 " " " "
to compleete frames 67, 70 - in woods
2002 toyota tundra.
12 yr old son has , 72 Charger, 78 Ramcharger and 85 ford wrecker
Frankd is offline   Reply With Quote
Old 11-29-2004, 10:56 AM   #2
gn4u2c
gn4u2c's Avatar
You just need to pull it apart and see if everything is in good order or worn out alot of times they just lossen up and you can retighted with a small anoumt of locktite. You do not have to replace everything just the bad parts all in all it only takes an hour to take it all apart and reassemble it.
gn4u2c is offline   Reply With Quote
Old 11-29-2004, 10:59 AM   #3
Russell
Professional Grade
Russell's Avatar
No, unfortunately....
Just take your time, and get creative when you work on it and you'll be able to do it yourself. Be sure to remember how everything came apart. You'll need a torx socket (I juse used a 15 mm I think...) a puller for some pin things (I used a bar with a screw that threaded in and popped them out by prying against a thick screwdriver) a steering wheel puller, locktite, and a couple of screwdrivers / sockets. The objective is to take those torx bolts out, put some locktite on them, and thread them back on.
So long as you watch how it all came apart, you can probally get it back together I'm sure someone will post the picture filled tutorial soon...
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 11-29-2004, 11:31 AM   #4
Slonaker
Insert Witty Text Here
Slonaker's Avatar
http://www.chevyasylum.com/column/tiltcol.html
http://home.t-online.de/home/O_Scholz/steering.html
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
