Old 11-29-2004, 02:07 PM   #1
john@thepier
john@thepier's Avatar
67-68 GMC vs 69-72 radiator support
is there a difference in 67-68 gmc radiator supports to the 69-up supports I have 69-up and would like to put a 67-68 hood on mine will I have to change the grill and support or just the grill. I know chevys are different just dont know about GMC
john@thepier is offline   Reply With Quote
Old 11-29-2004, 02:32 PM   #2
CPNE
Resident Curmudgeon
CPNE's Avatar
Assuming you mean 69-up GMC, then it'll interchange with the 67/68 GMC version. The single differenc is that you won't have the welded in nuts on the bottom edge to bolt in the lower valance. That valance was only on 67/68 trucks and you can delete it. You will need a 67/67 gmc hood latch however.
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
