11-29-2004, 04:24 PM | #1 |
Senior Moment
Need picture of Z bar
Does anyone have a pic of the Z bar that works the clutch? I need to know if it’s supposed to set at an angle or is it straight across from frame to engine?
Thanks Steve
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2019 GMC Diesil Dually. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
11-29-2004, 04:37 PM | #2 |
Chevy Nuttttt
it is suposed to be strait across
67' Chev swb step side 69' SS elky 03' Chev ext cab 4X4 hey who lernt me to spell is there anything else? |
11-29-2004, 05:45 PM | #3 |
Senior Moment
I took it all from a 69 and put it in a 71. My bar sets lower on the engine than on the frame so it is not straight across. Any Ideas? I'll try and get some pics tonight. Anybody have a pic of the frame where the Z bar mounts
11-29-2004, 05:48 PM | #4 |
Chevy Nuttttt
as long as it still works corectly it is fine. how far off are we talking?
11-29-2004, 05:50 PM | #5 |
Senior Moment
Its working fine but has broken the weld (was sweged) on the ball in the bracket thats bolted to the block. This is the same way it came off the 69??? Its about 1/2 inch lower on the engine side
11-29-2004, 06:01 PM | #6 |
Still drivin' a Rat Rod
I just went out and had a look,mine is angled a little toward the engine as well.If it's not hitting the frame,and not in a bind it should be alright.
Rusty Member #13872 Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#* 71 GMC LWB 49 Chevy 85 Chevy G20 Check out my website Last edited by Brainchild; 11-29-2004 at 06:05 PM. |
11-29-2004, 06:06 PM | #7 |
Chevy Nuttttt
the z bar was welded to the ball??? the ball should slide into the z bar and bolt to the frame on the other side. 1/2 is fine as far as being off. my elky was the same way.
11-29-2004, 06:07 PM | #8 |
Left Foot Functioning
Here's a pic from a stock 6cyl/3spd.
BTW, I do know that the frame bracket needs to be moved rearward 1.5" when going from I6 to SBV8 (factory V8 position) to get the z-bar running straight. SSOW
69 C10 (#1 son's ride) 72 C20 (Dad's farm truck) 82 K30 (Ex - brush pumper project) |
11-29-2004, 07:11 PM | #9 |
Senior Moment
Thanks stickshift, thats what I needed to see.
