Old 11-30-2004, 04:38 PM   #1
hotrodhomi
hotrodhomi's Avatar
Lower A arm replacement
Can I just replace the lower A arm on my truck, or do I have to replace both upper and lower as a set? I want to replace the stock lower arm with a tubular one, to gain clearance. ’81 SWB
hotrodhomi is offline   Reply With Quote
Old 11-30-2004, 06:19 PM   #2
rodnok1
rodnok1's Avatar
Some tubular are designed to be put on in sets, check the manufacturer for that. Otherwise no, you can just change upper or lower.
64 Panel Rebuild Pics
Clutch Replacement and Borg Warner T10 Trans Rebuild
64 Panel 1/2 Ton
350cubes/400hp
BorgWarner t-10
3:73 Auburn Posi
rodnok1 is offline   Reply With Quote
