11-30-2004, 07:00 PM | #1 |
Rear end swap
I tried to ask this on 60-66 board but there is no traffic over there so I thought I would try here. Can you put a 69 C10 12 bolt coil spring rear end in a 62 truck. Is it just a swap.
1998 Pontiac Grad Prix GTP 1969 C10 396 TH400 3.08 posi |
11-30-2004, 08:14 PM | #2 |
Fabricate till you "puke"
I havent done the swap, but my guess is both trail arm trucks, it should fit.....you may have to modify the track locator arm/brackets tho. best of luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
11-30-2004, 09:03 PM | #3 |
its all about the +6 inches
Like crazy al, I have never done it myself, but from what I hear, it's a direct swap.
11-30-2004, 09:48 PM | #4 |
it will go.......i have put a '71 (5 lug) rear in a '65. They were both coil spring trux
I don't remember any big snags.
67 C-10 shortwide '06 Triumph Thruxton '09 Harley 'Lectra Glide '95 Z-71 two door Tahoe |
11-30-2004, 10:27 PM | #5 |
Watch out for your cornhole !
You're going to have to modify the track bar I believe.
The early trucks had the track bar mount differently than the later ones did. IRONBUTTLCMC here did that swap and ran into that issue. Send him a PM with your question. He's a real nice guy.
12-01-2004, 01:51 AM | #6 |
Not a bad nut after all..
flip66, could you post what you learn on here? I'm also looking at doing this on a '62. I was told '60-'62 is different, but I don't know if this is true.
