Old 11-30-2004, 09:13 PM   #1
CT-Truckster
CT-Truckster's Avatar
Help me decipher this parts list
this is the poly graphite kit parts list from PST's site. Is there anything in this list here that translates into upper and lower control arm bushings?
Typical 2WD or 4WD Ball Joint type Front End Kit includes:
2 Upper Ball Joints
2 Lower Ball Joints
2 Outer Tie Rod Ends
4 Upper Inner Bushings
2 or 4 Lower Inner Bushings (as required)
2 Strut Rod Bushings (as required)
2 Stabilizer Links*
2 Sway Bar Bushings**
Control Arm Bumpers (most models)
*Trucks with conventional bolt type Stabilizer Links.
**Trucks with conventional "U" shaped brackets.
CT-Truckster is offline   Reply With Quote
Old 11-30-2004, 09:24 PM   #2
SanitysBane
i think that might be them
'96 Nissan Pathfinder
'02 Firebird Trans Am.
'88 K5 Blazer
SanitysBane is offline   Reply With Quote
Old 11-30-2004, 09:24 PM   #3
rolson1039
im assuming that the 4 upper inner bushings are the upper control arm bushings and the 2 or 4 lower inner bushings are the lower control arm bushings
so many trucks so little time!!!
rolson1039 is offline   Reply With Quote
