5 speed manual trans for 67-72
I will appreciate any info about posible bolt-in replacement of original 4 speed gearboxes with the 5 speed New Venture trans used in Chev trucks in the 90s. I have been told that the NV 3500 series is an easy fit replacement.
Does this work? Any serious wrinkles or mods involved? Is there a 4wd model of these units? Do they have PTO access? Thanks for any expert help. _______________________ 67 Corvette 69 C80 Fire Truck 69 K20 pickup lifted and powered up 70 C20 pickup 70 C30 Tow Truck 72 K5 Blazer 4 speed 72 K5 Blazer Auto 72 C30 Welding Truck with Utility Body (one off) 72 C30 Chassis Mount Camper 4 speed 72 C30 Chassis Mount Camper Auto Last edited by PDW; 12-01-2004 at 02:25 AM. |
I am not sure about the NV3500 but the NV4500 does have 2 pto ports. Both the 3500 and 4500 were available in 2wd and 4wd models.
1969 GMC K2500 ![]() 1996 Honda Accord 2007 Kawasaki KLR 650 |
kas68 has a T-5 in his truck.
Hopin`for more info here.I plan the same swap in the future.I have an NV4500 from a`95 4wd that I will eventually install in my`72 K/20 CustomDeluxe since it`s a manual 4spd.Actually,the 5spd will be sittin`behind the 6.5TD from same truck.
![]() Join Date: Jan 2004
I had an 89 Chevy with a 305 that had a Getrag 5-speed. It should bolt right up.
Good luck.
My Suburban Project 72 Suburban 68 SWB 57 Belair 55 Cameo 06 Chevy 1/2 ton crew 09 Suburban |
Advance Adapters makes a kit to install the NV-4500 if you want to keep your mechanical clutch linkage.
http://www.advanceadapters.com/catalog/041.html Bob
V-6....only GMC Trucks have it! 62 GMC W5000 NAPCO-V6 65 GMC 2500 NAPCO Panel-V6 66 GMC 1000-V6 66 GMC 1500-V6 67 GMC K1500-SBC (originally a KM-V6) 68 GMC C1500-V6 68 GMC C1500-V6 68 GMC Suburban C2500 70 Chevy K20-SBC 71 Chevy C30 Longhorn-SBC 72 GMC Suburban C1500-BBC 72 Chevy C10-SBC 72 GMC C5500-ToroFlow Diesel |
#7 | |
Silence is golden, duct tape is silver. - Scott |
