Old 12-01-2004, 02:47 AM   #1
HeavyD
HeavyD's Avatar
What can I use for seatbelts?
Hi. I want seatbelts in my 70 GMC that have retractable shoulder harnesses. What will work well in my truck with the least amount of fabricating? I see Chevy Duty sells some that fit from 1948-87...do these fit our trucks well? Any help will be appreciated..thanks.
"You can take the man out of PA, but you can't take PA out of the man"
HeavyD is offline   Reply With Quote
Old 12-01-2004, 08:30 AM   #2
70c10
67-72 Addict!
70c10's Avatar
I recently installed retractable lap belts in my dads 70'. I did a search on ebay for retractable seat belts and found both 2 point and 3 point kits for under $50. I bought 4 angle brackets ($2 each) at Home depot to mount. Julianos sells an anchor plate kit ($15) that I would recommend for floor strength to mount the retractors. It's pretty easy and they look great.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 12-01-2004, 10:12 AM   #3
jhwkns
Registered Cruiser
jhwkns's Avatar
I have S-10 belts in mine. They work fine.
I intend to live forever. So far, so good.
jhwkns is offline   Reply With Quote
Old 12-01-2004, 10:20 AM   #4
JimKshortstep4x4
Smile
S-10 belts work good. The passenger side hould be a direct bolt in but the driver's side needs the anchor point on the floor relocated.
Jim
Old 12-01-2004, 03:58 PM   #5
71Shortbed
71Shortbed's Avatar
Take a look at my post in this thread
http://67-72chevytrucks.com/vboard/s....php3?t=116099
I don't know what these came out of but they fit and work great.....
71Shortbed is offline   Reply With Quote
Old 12-01-2004, 04:27 PM   #6
RON WOODGEARD
Resident Young Old Dude !
Getr ahold of Shawn at www.****************.com. I bought driver, Passgenger, and center.. The two are retractable.... New and a few colors also..
RON WOODGEARD is offline   Reply With Quote
