Disc Brakes
OK found a 71 donor for my 68 is it a direct bolt on for the brakes from 71 to the 68 do i need to change controll arm or just the spindles Thanks
Watch out for your cornhole !
![]() Join Date: Jun 2003
You have to change the control arms too, because the disc brake spindles use different ball joints.
The control arms are a direct bolt on swap though. No problems changing them.
I trust you're aware of the drum vs. disc master cylinder differences?
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup. |
