Old 12-01-2004, 01:29 PM   #1
tkeduk8r
tkeduk8r's Avatar
what plug wires to use with headers???
I kinda stole the idea from the another post on the board relating to HEI and ram horns... but what kind of plug wires should i run with my new small block with summit headiers in my 74 2wd c10... I would like to run an 8mm ACDelco (i have a set i ordered for a 76 silverado since i have HEI) but I can return them on a set (76 vette maybe???) that may fit the headers better??? any suggestions or expereinces???
--Mike
63 C20 2WD, 230/SM420/4.11 73K
68 C30 dump truck, 327,SM425,4.56 66K original
68 C10 2WD SWB Stepper, 250/3-tree/3.73 66K.... Wifes
68 Buick Skylark Custom Conv., 350/TH400/2.56 In our family since '79
69 GMC 1500 SWB 2WD, 350/TH350/3.73 posi...
70 K10 SWB 4X4 4-sp,ps, pb, tilt, buckets, console, sliding back window (Need AC parts) WIP
72 Chevy K20 4x4 350/350/205/4.56 donor
72 Vette 350/M21/3.70 posi, triple black and super fast
84 Olds Cutlass Brougham 350/2004r/4.11 was Dad's
tkeduk8r is offline   Reply With Quote
Old 12-01-2004, 01:54 PM   #2
chickenwing
Lovin' Life in Miss.!
chickenwing's Avatar
I have cheapy flowtech headers. Made up my own wires from accel. I used a rail-type loom that bolts to the lower edge of the valve covers. Then found some heat resistant cloth? boot covers to slip over the plug ends. Looks good. Works good.
Here's a before pic that kinda shows the routing. I'm on the wrong computer for an after pic.
The truck... you hear that? No really, you did hear that?!!!
chickenwing is offline   Reply With Quote
Old 12-01-2004, 02:29 PM   #3
71swb4x4
71swb4x4's Avatar
I made my own wires and I will never buy another pre-fit set again. They are so easy to make yourself, and they will fit exactly how you want them to.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 12-01-2004, 04:01 PM   #4
rodnok1
rodnok1's Avatar
I used a set of 8.8 300+ Accel wires, they have adjustable boots so you change the angle at the plug. Very helpfull to keep the wires off the headers. I am also running the boots on the wires after 2 wires hit the headers with old looms. I also run accel shorty plugs, the help a little with plug installation.
64 Panel Rebuild Pics
Clutch Replacement and Borg Warner T10 Trans Rebuild
64 Panel 1/2 Ton
350cubes/400hp
BorgWarner t-10
3:73 Auburn Posi
rodnok1 is offline   Reply With Quote
Old 12-01-2004, 05:38 PM   #5
tkeduk8r
tkeduk8r's Avatar
thanks shawn and the rest... what kind of wires (brand) and I have never made my own, do i need a special tool??? Id like to keep and use delco wires, just cuz im anal.. but i may be cooerced into a better black wire.. Ive thought about Jacobs and Taylor, but i dont knwo too much about them... respond away!!!...
--Mike
Old 12-01-2004, 05:50 PM   #6
chickenwing
I do have an aluminum block that is used along with a safety razor to strip the wires. It also crimps the terminals. It was like 5 bucks at our local speed shop. You can do it all freehand but you must be carefull not to nick the conductor.
Old 12-01-2004, 09:15 PM   #7
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
msd has black wires, they also have the tool in the box, so no need to buy one
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
Old 12-01-2004, 09:20 PM   #8
Arrow211
try aurora plug wires.
They are the best made , but exspensive.
8.5 mm
All the racers here use them *W*
Arrow211 is offline   Reply With Quote
Old 12-02-2004, 10:28 AM   #9
rodnok1
rodnok1's Avatar
The accel wires are black and come with crimper in the box (it goes in a vise)
64 Panel 1/2 Ton
350cubes/400hp
BorgWarner t-10
3:73 Auburn Posi
Old 12-02-2004, 10:59 AM   #10
GreyHoundSteve
I used the accel cut to fit on my vette and they worked great. I also fought the little boots that go over the end of the plug wires and they work well also. I think jegs sells both ... or at least they use to.
GreyHoundSteve is offline   Reply With Quote
Old 12-02-2004, 11:43 AM   #11
chickenwing
That's their top of the line ones. The cheaper yellow ones do not come with a crimper.
Old 12-02-2004, 02:03 PM   #12
71swb4x4
71swb4x4's Avatar
Todd and I split a role of wire from Sturdevants. We bought a 100 foot role of 8mm, it was nearly $1/foot. I think I used around 20 feet to do my truck. All we used was the razor mentioned earlier and the crimping tool. Nothing too fancy. A little dielectric grease on the terminal helps slip the boots over and keeps everything corrosion free for a long time.
