Old 12-01-2004, 06:04 PM   #1
pimpallya59
frame chop
I have a 59 lwb 123" that i am getting ready to shorten for a fleetside short bed ; i know the wheelbase needs to be 114". so basicly i need to cut out 9" of frame and then reattach two peices , i've already cut the 7" off back to line bed up over wheels this was easy part next do i want to cut the frame like this==/ /=== or like this==] [=== . i was told that diagnal would be harder to get all true, but would be stronger; was also told to put a peice of channel insde frame and weld this in. i will not be doing any heavy haullin and plan to 4link it at a later day ,but for now would just like to get the bed mounted so i can keep on cruzzin. would like any advise on my plan of attack or any ideas you guys might have used in your projects also what should gap between cab and bed (i know there should be some clearance) thanks for any thing
pimpallya59 is offline   Reply With Quote
Old 12-01-2004, 07:00 PM   #2
Slams_58
none of the above. The BEST way to do it is in the link below
http://207.44.196.117/vboard/showthread.php3?t=123624
It is easy to line up and gives you the most strength in your frame
Slams_58 is offline   Reply With Quote
Old 12-01-2004, 09:12 PM   #3
pimpallya59
so basicly use his notch , but my frame (wheelbase)cant be 12" to long i got 9 maybe 9.5" but not 12 , and scince i have a 1ton and dont have a two peice drive shaft can't i cut behind cab or under bed , in front of diff; not to taint the frame for future mods, also does the cab have to come off? he deffinetly did a nice job but my frame has some different options
Old 12-01-2004, 09:47 PM   #4
DennyB
Led Sled! Discs R 4 ME!
DennyB's Avatar
Do the same type of notch with your 9" (or 8").
Set it up with your cab and short bed on it and measure.
You might find out you like 115" better.
If you look at the stock short beds, the wheels are not perfectly centered in the wheel openings.
I have not set this up yet myself so I am unable to tell you where shift the frame, but its worth taking a look at before you cut
"Never ride faster than your Angel can fly"
I.M.O.M,W,J&C
Patriot Guard Rider
DennyB is offline   Reply With Quote
Old 12-01-2004, 09:56 PM   #5
pimpallya59
what is the gap between a stock swb fleet side does any one have pics? because the fleetside wraps the ends . it would be nice if i could get a look at a fleetside bed on a truck to look at gaps
