Old 12-01-2004, 06:27 PM   #1
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Id these brackets please
I believe they are small block ac brackets:
and
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 12-01-2004, 06:50 PM   #2
724wdcopper
graphic designer
724wdcopper's Avatar
the small boomarang shaped one on the right looks like a starter brace to me. the others do apear to be SB AC stuff. I bet the boomarang one fits the stud at the fat end of the starter and bolts to the block with an existing hole/bolt.
not 100%, but that is what my starter brace looks like.
724wdcopper is offline   Reply With Quote
Old 12-01-2004, 08:38 PM   #3
chickenwing
Lovin' Life in Miss.!
chickenwing's Avatar
Still kinda weak on the scanner. Best I could do.
The truck... you hear that? No really, you did hear that?!!!
chickenwing is offline   Reply With Quote
Old 12-01-2004, 08:41 PM   #4
Randy70C-10
Randy70C-10's Avatar
Yep, that's what it is.
Randy70C-10 is offline   Reply With Quote
Old 12-03-2004, 11:18 AM   #5
72CSTC5
72CSTC5's Avatar
I do not want to take away from anyone's deal going on here but after the above deal is done I have some a/c brackets for a smallblock chevy that I will not be using if anyone else needs them. I will have to see how much of the original setup I have this weekend when I go home.
72CSTC5 is offline   Reply With Quote
Old 12-03-2004, 11:30 AM   #6
Dean
Dean's Avatar
Definate starter brace for the boomerang one. I have them on both of my K20s. They do make different ones depending on your starter/engine though.
Dean is offline   Reply With Quote
Old 12-03-2004, 11:58 AM   #7
LT4XTREME
The boomarang shaped one is a starter brace. A small block starter brace a big block starter brace is shorter with less curve. The bracket in the first pic just below the compressor to the right a flat bracket with 4 holes is a pass side lower alt mount for a long water pump small block. The 2 holes in the one end go to the pump the one on the other end goes thru the bottom of the alt and the hole in the middle is for a A.I.R. pump. I had this bracket on my 80 el camino ss and made one out of a plate of stainless steel without the hole for the A.I.R. pump.
LT4XTREME is offline   Reply With Quote
