Good front brake upgrade kit?
I will need to do the front brakes soon and its about time to replace this crap.
I like Stainless Steel Brake Co. (SSBC) products and have been looking at their stuff. I want a kit with new rotors, calipers, and pads w/ hoses and bearings if possible. I know they offer a rotor and pad kit for around $280.00, but I want a kit that includes the calipers. I see they do have a pricy kit that includes spindles, but I dont need those. I could have sworn that someone posted about this SSBC kit before. I sent SSBC an email about this and waiting for their reply, I figured with all the rotor talk Id ask about a whole kit. I am willing to consider other good brands (Brembo, Wilwood, etc.). Eventually I will do the rear end disc conversion kit, but will not have the money this go around.
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION * |
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
Those are the Force 10 kit, the calipers they use require the spindle for mounting.
7T7 got the Baer brake kit.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
Under construction!
I purchased the "Big Brake Upgrade Kit" from SSBC. It includes rotors, pads, calipers + hardware, bearings, seals, and everything else you need for a complete front brake rebuild/upgrade. It's only for 1-1/4" trucks though.
Swervin Ervin has this same kit and I'm very happy I took his recommendation. Add a pair of Goodridge stainless steel braided hoses and you'll be set! ![]()
2001 Silverado bagged on 22's. *Sold* |
You get what you pay for
Here you go.
Front Big Brake Disc Brake Kit Not cheap by any means, but it is nice and I would buy it again for sure. Everything you need except for hoses. But, you must have 1.25" spindles though. Mike |
Gentleman Jim Driver
Isn't the SSBC kit just using stock size rotors that have been slotted with 1 ton calipers and pads? Seems like you could get those parts locally cheaper.
Joe '75 GMC Gentleman Jim '84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter) '85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '89 R3500 Flatbed |
I believe my truck has standard brakes, not heavy duty but Im not sure.
Where do you measure the spindle to determine if I have the 1.25" spindle? What would the other size spindle be? Mike, did you change spindles to use this kit? I have 15" wheels and dont plan on changing them anytime soon, so the kit needs to be able to fit stock size wheels. I will look into the baer kit. Edit: WOW I didnt know this, but Baer is just a few miles away from my house. They happen to be a few miles away from Performance Suspension and the UPS hub. Looking at a map online its a little hidden in some industrial buildings in that area. Ill have to go by there and check them out. Maybe they have a store in there or something.
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION * Last edited by PHOENIX; 12-02-2004 at 12:29 PM. |
#7 | |
Garage Queen Material
So this is at the largest part of the spindle shaft?
I am considering a front / rear conversion, from Aerospace Components, buddy of mine has set on a drag car and quality looks very good and a reasonable price.
Go to www.aerospacecomponents.com and look at the Pro Street set up, 4 piston caliper, vented rotors, hardware ,etc., good quality stuff. I think you can do front and plan on rear later with them.
86 GMC SWB, DK. BLUE, ZZ430,TH400, 4.11'S, HEADMAN CERAMIC HEADERS, WELD BILLETS, BFG 275 / 60 / 15, 325 / 50 / 15 DRAG RADIALS, FIBERGLASS COWL HOOD, B&M SHIFTER. MSD, MARCH PULLEYS / ALT. / PWR. STEER PUMP, BECOOL RAD., BILLET GRILL & GRANT WHEEL. |
#10 | |
#11 | |
yeller
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
#12 | |
#13 |
ROCKET POWER!
So do diesel powered trucks.
What did i do last nite? I had a wonderful time, That's what they tell me What did i do last nite? 1979 C-10 shortfleet: Olds 350, Th400, 12 bolt Current project: 1969 Olds 455 W-30, needing a rebuild |
#14 |
Eddie,
no I didn't change spindles. My truck came with 1.25" spindles stock. I have 2.5" drop Western Chassis spindles now. The Big Brake kit is basically the same as stock 1.25" spindle stuff, except for the slotted rotors. The calipers look the same as stock 1.25" calipers. One big difference in buying this kit and buying local stuff is everything is new. No rebuilt junk here. It all looks like first class stuff to me. If you price all the stuff local I think you would be hard pressed to get it much cheaper. Have you ever found any new (not rebuilt) calipers anywhere local? I looked everywhere and could not find any. Have you priced slotted rotors, bearings and seals? $625 clams is nothing to sneeze at I agree. I guess it's all a matter of how much leg work you want to do. I always did love to do one stop shopping. ![]() ![]() Mike |
#15 |
Yeah Mike I hear ya.
I priced some stuff from the local dealers and when you look at rotors and calipers the price starts to rise pretty quick. $625 doesnt sound too bad for the kit. Would be nice if it came with hoses though ![]() Im sure the stuff could be found cheaper, but I do agree the hunting and running around can take some time. Plus its nice to know all the stuff came from blank blank and not have to figure out where you bought a part. I know I can find new calipers local, Baer is just a few miles away ![]() I sent them an email about kits they offer and have not received a reply yet. 1. Did you notice any improvement in stopping or noise? 2. Does that kit come with any hardware for mounting the calipers? 3. Does everything bolt right up (if you have 1-1/4" spindles) without modification? -- I read on one site that you have to cut stuff, drill and tap for a different kit (not SSBC). 4. Are the pads the same dimensions as stock?
#16 |
Eddie,
it comes with everything you need, except for hoses. New caliper bolts included. No drilling or cutting. It fits like a glove. You will have to install the bearings and seals of course and don't forget to grease the bearings. ![]() Since I already had big brakes anyway, I didn't really notice a difference in stopping but I've not driven it real hard or stopped real hard with it. As a matter of fact, I don't drive it much at all lately. I've been so busy with other stuff and haven't had the time. It's not a daily driver anyway and just sits quietly in the shop. I imagine it might be getting pretty lonely too. ![]() |
#17 |
Also those with this SSBC kit, are the calipers the same as stock?
The piston on these stock calipers doesnt look like it can get any bigger and still work with the pad.
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION * Last edited by PHOENIX; 12-05-2004 at 03:26 AM. |
#18 |
Measure the rotor width, not the spindle. Its somewhat misleading to call them 1.25" spindles they are really 'the spindles that fit 1.25" rotors'
#19 |
thanks Joe
![]() I wasnt reading well enough above. The rotor thickness is close to 1".
#20 | |
