WTB Mini starter
I am looking for a mini starter fot my BB chevy with a 153 tooth flywheel, I would like something around 2 horse.
Youth soon passes away, but immaturity can last a life time. |
Windy Corner of a Dirty Street
I guess anything is possible but I never heard of a 153 tooth BB flywheel. The vast majority of GM SB and BB are 168 teeth.
I run a 1999 L29 454 starter in my 78” K10. The starter is tinny, high torque, sounds cool and much less expensive than the aftermarket pieces. GM part number: 10465167 Cost: $149.60 (per gmpartsdirct.com – they’ll screw you on freight….don’t buy from them…they sell parts at dlr cost then mark up the freight like crazy)
Current vehicle collection: 1978 Chevrolet K10, 8.1L, NV4500, NP205 1989 Chevrolet Suburban, 8.1L, NV4500, NP241 1993 Chevrolet C1500 Sportside, TBI 7.4L, 4L60E 2001 Chevrolet K2500HD, Ext Cab, SWB, 8.1L, ZF 6 speed 2014 Chevrolet Impala LTZ 3.6L Vortec 8.1L because life is too short to tolerate underpowered vehicles
Thanks for the tip on the starter. Do you know how much compression that starter will turn.
The 396/427 chevy motors are internally balanced like the small blocks (excluding 400 and 383) so the flexplates are pretty much interchangable.
#4 | |
350’s, 396’s, and other internally balanced Chevy engines also use 168 teeth flywheel so either way, you shouldn’t have a problem using an off the self late model GM starter. You will have to add something to fill the gap in the dust cover though. The picture I posted was right after I installed the engine….before the starter wiring harness was loomed, closed the temporary O2 sensor port and filled the starter gap with a cut heater hose.
