Old 12-01-2004, 10:28 PM   #1
Russell
Professional Grade
Russell's Avatar
Dissconnecting ebrake?
I'm about ready to pull the cab off my 74, but have no idea how I should get the ebrake off... So far I've pulled the brake lines, all the wiring, the cab mount bolts and the steering column. Is there anything else I might be forgetting?
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 12-02-2004, 01:44 AM   #2
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Just throwing these out there... Ground straps? Speedo cable? Brake lines? shifter linkage?
Are you asking how to get the ebrake cable out? If so, you have to squeeze it from the outside and get it to go up through the hole. It has "teeth" on it that holds it in. It is a pain to remove.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
