Old 12-01-2004, 11:12 PM   #1
wolfthing2000
Dana 44 front axle pinion splines
Are all of the pinion shaft splines the same for the front Dana 44s??? I just opened up a set of ring and pinion and the new pinion gear splines look to be rather fine.. What is the spline count for my 69?? and are all years the same or am I looking at a change of yokes also ???????? ( ?? MORE $$$$$??????) Thanks,
Dave
wolfthing2000 is offline   Reply With Quote
Old 12-02-2004, 01:58 AM   #2
'71c204x4454
'71k204x4454
Well I don't know if this will help or not but my '71 has 30 splines and the '75 that I got as replacements has 30 also.
1971 K20 4x4
1964 buick skylark convertible
'71c204x4454 is offline   Reply With Quote
Old 12-02-2004, 01:15 PM   #3
wolfthing2000
26 for the new one I got. HHHMMMMMMMMMMM!!!!!!!
Old 12-02-2004, 05:33 PM   #4
wolfthing2000
ttt
Old 12-02-2004, 06:43 PM   #5
Blazer1970
Blazer1970's Avatar
26 splines is correct for the pinion. I think '71k204x4454 is talking about axle shaft splines.
Blazer1970 is offline   Reply With Quote
Old 12-02-2004, 11:34 PM   #6
wolfthing2000
Talking
Right you are!!! I pulled off the yoke tonight and there they were ,, the 26 fine looking splines just like the new pinion that I picked up. I am more used to the older Jeep stuff that had the heavier ( not necessarily stronger) coarse splines ( 10 I believe ).. I am assuming that the involute splines are far stronger as they did it for a good reason.........I assume!
Dave
Old 12-03-2004, 12:09 AM   #7
1969 GMC
1969 GMC's Avatar
yes more splines = stronger
where the splines contact each other, there is more surface area on higher # splines
also, when more splines are used they are smaller, and the diameter of the shaft (if you took the splines off) is larger in diameter, which makes it stronger.
EDIT: sorry for all of my highly technical terminology :p
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
