Still drivin' a Rat Rod
back brakes from a 76 fit?
The rearend went out of dads 72 yesterday,and so he pulled the 3rd member from a 76,and bolted the ring gear up,and bolted it right in.Even has the same spline axels,and ect.
The back brakes are an inch maybe an inch and a half wider than the ones on the 72 though.Would they also fit,using the backing plates from the 76,or would I have to use the axels too?If I have to use the axels they may be too long which would make the whole deal not worth it for no more gain than I would get . How much of a difference would there actually be,would it be worth it at all?
Rusty Member #13872 Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#* 71 GMC LWB 49 Chevy 85 Chevy G20 Check out my website |
![]() Join Date: Aug 2001
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
Did you use the axels from the 75,or the 72 when you swapped it out?
I believe the axles are the same length, the difference in the backing plates allows the use of the wider shoes.
#5 | |
