Old 12-02-2004, 03:37 AM   #1
ocbaud
Garage Queen Material
Intermittent Wiper problems
my truck came with this option, but it has never worked.
what can i do to fix it? the wipers work at the only 2 full speeds, but the pulse ones dont
ocbaud is offline   Reply With Quote
Old 12-02-2004, 11:22 AM   #2
Mike76251
The little module that is right under the column (behind that plate) is prob. bad.
The electronics inside can't take much heat and they fry at a pretty fast rate.
I have bought two from GM in the last 10 years and I am not gonna fix it again.
Mike76251 is offline   Reply With Quote
Old 12-02-2004, 01:03 PM   #3
86-C10-V6
Shadetree Mechanic
86-C10-V6's Avatar
Take the control module apart.
Mine quit or was intermittent and I took the control module apart thats at the base of the steering wheel and found broken/cracked solder joints on the PC board, touched it up with a soldering iron and has been working fine since then.
Dave M. (Hacksaw)
86 C10 Scottsdale LWB, 4.3L, Edelbrock 1904, K&N, 700R4, 3.08 Auburn Performance
89 GMC S-15 Extended Cab 4x4, 4.3L, FI
98 K1500 Xcab, 5.7L, 3.43 Gov-Lok
86-C10-V6 is offline   Reply With Quote
Old 12-03-2004, 04:07 AM   #4
Mike76251
That's not a bad idea............thanks!
Old 12-03-2004, 07:20 AM   #5
TwinTurbo
TwinTurbo's Avatar
Mine does the exact same thing, it definetely is the control module.
TwinTurbo is offline   Reply With Quote
