Need your input please....
Ok I know this has been hashed over more than once,,,,Cutting the dash for a modern CD Player. I have always been on the side of "NOT" to cut the dash if it had not been done by the PO and to re-locate your modern radio somewhere else. Well, I've got to the point where I am installing a nice modern high powered stereo system and the more I look at it the more I keep telling myself to "Just go ahead and cut the dash for the radio".
![]() ![]() Thanks for you input.
Alex 1971 Lil' Red 350 SBC 700R4 |
It is your decision.
I will probably cut the dash when my truck goes back together, these trucks are not the rare collectibles that corvettes are. They only mean something to us as the owners.
You see a few factory restored trucks, but for the most part they are a result of our automotive individualism. I have considered a custom made console for a modern radio as well, either in the usual place or an overhead cosole for the radio. Regardless we will all have a big unused space if we don't use the original space for the radio.
ongoing 1970 c 10 lwb ![]() 1994 z-28 few mods.-owned since new ![]() 1978 vette silver/grey 25th anniv. paint ![]() |
I debated this on my 64, & finally decided we are NOT going back to AM & I didn't want to operate a radio in the glove box or other hidden area. I was careful & cut & installed a CD player & I couldn't be happier. I used a kinda plain one as I thought it would look out of place with lots of lights,graphics, etc. I used 2 4x6 plates in the OE speaker location & hid 2 5x7s under the seat. Sounds good but I need a sub, not quite enough bass. Brian http://pg.photos.yahoo.com/ph/peepeeman00/my_photos
I'd cut it and put it in the dash. Save the space for other stuff.
Dan |
![]() Join Date: Feb 2000
Do what will make you happy. If the truck isn't going to be restored as a show piece, then cut it and use the dash to hold the new radio. It will be where it belongs, be within your reach and should look good setting there.
There are alternatives if you really don't what to cut the dash. such as the Glove Box, under the seat, below the dash, in a console... |
![]() Join Date: Dec 2001
Hack away!!
1942 Master Deluxe 1969 C/10 1985 Blazer CUCV 1987 Jimmy 2004 Tahoe 2005 Silverado 1500 2005 Silverado 3500 |
Personally i would cut it. It's YOUR truck now so do what YOU want with it. Now as far as my decision process goes .... i guess it depends on what your trying to do with your truck. If your keeping everything else stock on the vehicle then i would go through the extra trouble of relocating the deck somewhere else but if you plan to do other mods that will update the apearance of your truck then go ahead and cut it .... if its cut right then im sure the next owner will thank you vs being upset with you.
Ive never seen ANY head unit that fir tyhe factory opening that didnt look goofy. EVERYONE with a decent stereo usually cuts this out and replaces it with a modern unit. Just dont make a mess and im sure no one will mind. |
They truck has definetly been restored to a show piece...Just not an original show piece. I went at it in the "Resto-Mod" fashion...and that's why I'm leaning towards the cutting of the dash.
I don't approve of cutting dashes, but the bottom line is it's YOUR pickup! Cut it if that's what you want to do. If someone gets grumpy with you, tell them what they can do.
my 2¢ - t.i.o.l.i. Bowen 1968 K20 fleet 1969 K10 swb fleet 1972 K10 Suburban 1972 C10 lwb step 1992 K1500 'burb 1995 K2500 'burb 1997 C1500 'burb 1999 K1500 2000 K1500 'burb Why do I own so many Suburbans? |
I am having a similar dilemma with the '56 Bel Air I have. it also has the delete plate and no antennae hole. Here is my solution:
I am going to figure out a way to mount the radio behind the delete plate. Then I will somehow hinge the plate so that it will swing down to get to the radio behind it. I haven't got it all figured out yet, but hopefully I will soon. If you figure it out before me please take some pics so I can imitate your design. I will do the same if I get it done before you, but I seriously doubt I will.
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
Out draggin'
I don't believe in cutting dashes either. I am putting my STOCK AM/FM in the dash where it belongs and I am putting my MODERN AM/FM/CD player in a GM Tissue dispenser mounted under the dash. They look clean & fit perfectly inside them and no damage to the dash SHOULD you ever decide to sell the truck to someone who may not want the DIN hole in there...
91 GMC Xcab LB-Bags/bd/caddy clip SOLD 72 C10 Cheyenne Super LWB SOLD 92 GMC K1500 Burb 72 C10 Burb (ex. Cheesewagon)SOLD 72 C20 Burb parts truck 71 C10 Burb "project" |
Where's my beer?
Hey jorgen, you have a good idea, but keep in mind, you won't have room to put a CD though if that's what you are aiming for. However if you're planning using a changer, then I think you've got a great idea.
70 C10, shortstep, .30 over 250,Hurst shifted 3 spd parts hauler. Holley 390, Clifford Intake, Header, ported cylinder head, unknown bigger cam. 79 Corvette L82, 4 spd, black, red interior, headers, flowmasters, and unkown bigger cam. '03 Grand Cherokee Laredo, 4.0 4x4 daily driver. 165K miles, and runs great '08 Tahoe LTZ 4x4 155K |
#13 |
![]() Join Date: Nov 2004
If you really don't want to hack your dash you can get a "new" stereo that has am/fm cassette and hookups for a cd changer from custom autosounds... http://www.classicperform.com/6092chevtrk.htm#stereo but it will cost you about 380 bucks minus the cd changer. The previous owner of my truck made my radio decision for me by hacking the dash, so I straightened up the cuts and put in a 240W sony x-plod cd player with a wood insert. I think it looks cool. So I would say hack away....but to the guy with the 56 bel air....I personally think that should be unhackable! I also like the smooth cowl. I got one from a junkyard that didn't have a hole and put it on my truck.....but where to put the antenna??? I bought a cheap Wal-Mart antenna and drilled a hole next to my gas tank behind the seat. The antenna is completely hidden and with a power booster, don't know where to get one...it was in my truck when I bought it, I have good reception....
#14 |
yeller
I don't care for cut dashes either...so I am going to purchase a Custom Autosound stereo and hide the CD changer behind the seat. From what I gather, CA units are pretty nice and of good quality, plus they have the built in changer controls.
![]() EDIT - 67chevyredneck, you beat me to the punch. ![]()
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
#15 |
It sounds like you don't have a remote, so you want the head unit within sight and easy reach of the driver. Only in-dash, under-dash, in a center console, in an overhead rack/console, or in front of the seat mounted vertically qualify. In an overhead rack would be second best. Since you have a 4x4, in an overhead rack made part of an in-cab cage would be best. With either, no cut dash and out of sight of thieves. With the cage, you could mount & lock the head unit in a rack made of 1/4" steel plate that thieves can't easily cut like the dash. Choose away.
For the posters who didn't notice that ChevyDude already purchased a deck, a CAS AM/FM unit with CD changer but no cassette unit has no worries. But a CAS AM/FM cassette player, with or without CD changer hook ups, lacks both Metal/CrO2 equalization capability & Dolby B Noise reduction, so beware if you use CrO2 or Dolby B recorded tapes, since with a CAS casssette player you'll get distorted sound quality.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup. |
#16 |
It's not a cassette deck...It's the Pioneers top of the line CD, MP3, XM ready deck.
#17 |
jorgensen, here is slammed67's radio, sounds like what you are trying to do.
![]() ![]() Very clean install.
#18 |
I don't know anything about the sound quality of CAS head units but if they sound anything like their speakers I sure wouldn't buy one. I put in one of their dash speakers and it sounds lousy.
![]() ![]() 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
#19 |
As already stated, it's your truck, do what makes you happy. You are the one who drives it and has to feel comfortable operating the stereo while driving safely. So if in the dash is the most comfortable place for you then go for it.
I always liked the look and feel of an over head console. When money allows it I'll put a am/fm stereo in the factory hole and put a cd player over head. Here is a question: Will a cd deck work properly mounted in a vertical position?? |
#20 |
Keepin an eye out
Cut it and install a bumpin system
1970 Chevy C10 SWB 5.3 1996 Toyota Tacoma SR5 4x4 2007 Vespa GTS 250 Scooter ZIP 91351 |
#21 |
72 GMC SWB
do it DO IT ...well......errr.......do what you want its YOUR truck
#22 |
I like how you have a cover over it so that it looks like you dont have a stereo i would try to keep it that way
Guys 71 350/Muncie 4 spd. Son of 1970 CST Short Wide ![]() |
#23 |
ive cut my dash, on both my 70 and 72, right now there isnt a radio in the 72, it got traded to the 03
#24 |
This, is my BOOMSTICK!
If you are torn, just cut the area out carefully to fit your new stereo. Save the cutout and if you ever feel the need you could weld it back in.
Option #2 if you didn't have a stereo already is LMC sells stereo's for these trucks that fit the dash. You can get a cd stereo through them as well. I don't know the quality but that's the route that i'm going.
Larry Got rid of my projects for now. 1980 Jeep CJ7 1998 Nissan Sentra (my car) 2001 Toyota Sienna (wife's, of course) |
#25 |
id never cut a dash on a truck that old but thats just my opinion you do what makes you happy
so many trucks so little time!!! |
