Old 12-02-2004, 11:43 AM   #1
hambone1958
hambone1958's Avatar
WTB Rear housing seats
I need a pair of rear end housing seats, perches or pads for a leaf spring rear. They are the saddles that go under the housing and u-bolt up over the leaf springs. Anybody know what i'm talking about? Does anybody know where to find them?
Alan
hambone1958 is offline   Reply With Quote
Old 12-02-2004, 12:29 PM   #2
junkyardjohn
junkyardjohn's Avatar
LIKE THESE??? $25 SHIPPED TO THE LOWER 48
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 12-02-2004, 01:05 PM   #3
hambone1958
Kind of but mine have 2 holes in the front and 2 hole in the rear that the u-bolts go thru.
Alan
Old 12-03-2004, 06:21 PM   #4
junkyardjohn
SORTA LIKE THESE????
junkyardjohn
DON'T RENT U-HAUL
Old 12-03-2004, 08:52 PM   #5
Rod
Just a note I had to look for these once myself...and there are difference between leaf sprig rear for a 4x4 compared to a 2wd in the 1/2 tons. They are a different tube size between the two.
There are casting numbers in the 2nd style posted brackets to make sure you get the ones you want.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 12-04-2004, 05:44 PM   #6
junkyardjohn
I'M PRETTY SURE THESE ARE OFF OF A 71 OR 72 4WD BLAZER. (I GOTTA START TAGGING SOME OF THIS STUFF & QUIT RELYING ON MY FAILING MEMORY) JOHN
junkyardjohn
DON'T RENT U-HAUL
Old 12-06-2004, 08:37 AM   #7
hambone1958
Those are like mine I need the 2wd 1/2 ton pickup version. Ed at mothertruckers has a set I'll call him today to check if they are 2wd. Thanks for all the help. I couldn't do this project without you guys and this board.
Alan
Old 12-06-2004, 10:48 AM   #8
MOTHERTRUCKERS
The set i have here are 2 7/8 x 3 1/2 center to center 2wd leaf.
Rest in Peace Ed. Thanks for all the good times.
MOTHERTRUCKERS is offline   Reply With Quote
