Old 12-02-2004, 07:09 PM   #1
71Blazer
Goodbye Darlin'
71Blazer's Avatar
WTB HEI distributor
I posted this in the 73-87 parts board but I thought I'd give it a shot here too.
I've got a 400 small block of 74-80 vintage in my 71. I want to upgrade from ponts to HEI. I'm looking for a distributor in good running condition with vacuum advance. I would prefer one with a more powerful coil than stock but in the end the budget rules all...
1971 Blazer CST SOLD!
71Blazer is offline   Reply With Quote
Old 12-02-2004, 07:19 PM   #2
72_Chev_Truck
i got one but it cost me a cam, i dont think you want it
72_Chev_Truck is offline   Reply With Quote
Old 12-02-2004, 07:26 PM   #3
71Blazer
Goodbye Darlin'
71Blazer's Avatar
Uh, probably not. But I like a good story
Old 12-02-2004, 08:29 PM   #4
racer94
i got one,works exellent and has vacum advance....it has a msd hot coil as well as a hardened drive gear..take $60 for it shipped.....has accel cap and rotor as well.
racer94 is offline   Reply With Quote
Old 12-03-2004, 03:17 AM   #5
72_Chev_Truck
welp you see, it was about 10 degrees outside in southern mn, i had just picked up a lady friend and we were going for a drive. I couldnt afford to buy light oil for winter on the last change so i used the 15w40 out of the 55 gallon barrel. so i get on it at a light and all of a sudden the truck just dies. after i heard a loud snap. couldnt get the truck restarted so i call my dad to come tow my chev to the mechanic and he pulled the distributor out to find half the teeth gone (bought the hei from the junkyard for $35) figures, he looks at the cam and notices teeth missing there so i had him put in a cam and then he put on a brand new hei and out the door i went.
Old 12-03-2004, 11:42 AM   #6
racer94
running oil too long will also cause it to do that...i get trucks in the shop all the time that dont change there oil often enough and it in tern locks the distributor up and strips the teeth off the cam,distributor and usually the timing chain ....
Old 12-03-2004, 12:21 PM   #7
72_Chev_Truck
i change it every 3000 so i dont think i ran it too long, i think it was just too thick with a high volume pump and possibly a hairline fracture in the dist. gear.
Old 12-03-2004, 09:57 PM   #8
71Blazer
Goodbye Darlin'
71Blazer's Avatar
Something to avoid... One more good reason for the drudgery of maintenance.
Thanks racer94, PM sent
Old 12-04-2004, 03:16 PM   #9
BurnoutNova
BurnoutNova's Avatar
i have a good stock one, came from a gret running 350.
30$ plus the ride
BurnoutNova is offline   Reply With Quote
Old 12-04-2004, 08:50 PM   #10
Mint68
Mint68's Avatar
HEI good deal
30$ plus the ride
I think it sounds like an awesome deal! I am interested if nobody else takes it. Let me know ASAP
Mint68 is offline   Reply With Quote
Old 12-04-2004, 11:26 PM   #11
72_Chev_Truck
here is whats left of one, ill sell it real cheap
Old 12-07-2004, 04:42 PM   #12
71Blazer
Goodbye Darlin'
71Blazer's Avatar
72_Chev_Truck, That drive gear took a beating!
BurnoutNova PM sent, thanks
Old 12-07-2004, 05:34 PM   #13
454_72_4X4
454_72_4X4's Avatar
72_Chev_Truck how much is cheap? From the looks of the pics you've already taken the gear off, is the shaft hurt?
72 C20 4X4 454 4 speed
89 Trans Am (was) 305 TPI 700r4
93 C1500 2wd Extended cab 350 700r4
98 Sonoma (TPI outa the Trans Am)
03 Yamaha 660 Raptor
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
454_72_4X4 is offline   Reply With Quote
Old 12-07-2004, 06:02 PM   #14
Dick Dale
Excelsior, You Fathead.
Dick Dale's Avatar
My old man did that back inthe day to his GTO..He just got on it the same time it seized. Ouch.
Go Navy. The Sea Is Ours.
Budget 350 Build
http://67-72chevytrucks.com/vboard/s...38#post2264638
Dick Dale is offline   Reply With Quote
Old 12-07-2004, 07:28 PM   #15
72_Chev_Truck
i think its good besides the gear, you can slide the shaft up and down in the housing if i remember right, but maybe that is something that can be fixed. cheap is $10 shipped
