Old 12-02-2004, 11:43 PM   #1
OL BLUE
Brakes ?
im sure this is a repost but, when i start on my truck id like to add disc brakes. i dont wanna spend big bux on aftermarket stuff. i just wanna know what fits from other years trucks or whatever i can find at the boneyard. ive got a 67 c20. i know some of the 71-72s had discs but they are gettin hard to find in salvage yards. will 73-up parts work? what years and what all will i have to pull from the donor truck? thanks in advance for any help you can offer.
current projects:
67 c20 w/350 4spd
74 camaro 355/th400
83 malibu wagon
80 malibu wagon
OL BLUE is offline   Reply With Quote
Old 12-03-2004, 12:14 AM   #2
Brainchild
Still drivin' a Rat Rod
Brainchild's Avatar
Welcome to the boards
You'll have to have the spindles,and tierod ends.All the brake componets,lines,calipers.
Plus you'll need some adapters to male the two tierods mate up,one is a different size.Some one here can tell you where to get those.
Rusty Member #13872
Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#*
71 GMC LWB
49 Chevy
85 Chevy G20
Check out my website
Brainchild is offline   Reply With Quote
Old 12-03-2004, 12:19 AM   #3
bluec10
bluec10's Avatar
You have several options:
1. Find a 71-71 C-20 at the wrecker that has disc brakes. You can keep the same ball joints - simply swap in the 71-72 spindles and find a mc/booster/proportioning valve for disc brakes.
2. Using later components is also possible, but a bit more work. What I'm doing is replacing the entire front crossmember in my '69 with a crossmember from an '84. In my case the entire crossmenber just swaps in and only two new holes need to be drilled. Perfect fit. You'll still need to get a mc/booster/proportioning valve set that works for disc brakes.
Have fun.
Present:
2015 Tacoma. Yeah, not a GM, but I love it.
1969 GMC 32,000 - fix, drive, relax, fix...
2019 BMW R1250 GSA - Yahoooooooo
1979 Honda GL 1000 - retro touring at its best.
Past:
'05 Sierra 4x4 - Had 270,000 KM and running well when it was written-off by a stop sign runner.
'94 F-150 from the "F word" company. I'll admit it...good truck. Sold what was left of it for $800 to a guy who came to pick it up at 11:00 PM with cash in hand. Hmm.
'79 Sierra Grande (Black) organ donor - perfect rebuildable 4-bolt 350 and a good TH350.
'76 Sierra Grande (Orange) - hate isn't too strong a word. Kid who bought it turned it into a hot rod.
'68 C-10 R.I.P. - Dad's old truck...too far gone to resurrect.
'59 C-50 - with hoist. Truck is gone, wife isn't. Nuff said.
bluec10 is offline   Reply With Quote
Old 12-07-2004, 12:26 AM   #4
OL BLUE
so the 73-up parts will work? do i have to change out the whole crossmember? or will the spindles just swap out? i know ill need a new ms and prop valve and all. i just need to know what will work for sure on the spindles and discs.
current projects:
67 c20 w/350 4spd
74 camaro 355/th400
83 malibu wagon
80 malibu wagon
Old 12-07-2004, 12:55 AM   #5
GMC3
the spindles will fit, just use the 73- up ball joints, they fit right into the older a-arms. If i'm not mistaken, when doing it this way you will lose a little bit in the turning radius, but it will work
GMC3 is offline   Reply With Quote
Old 12-07-2004, 01:59 AM   #6
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
you can grind off the steering stops and get the radius back. some people say that the easiest way is just change the cross member, but to do it right you still have to take it apart and put new tie rods and ball joints in. you can bay a whole conversion kit from some of the board venders on the front page, or go to the junk yard and scrounge up the parts you need. what ever you do if you go to a yard, make sure that you remember the year of the truck that way you can buy the tie rods and ball joints for that year
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
